Question about Refrigerators
'fridge showing 1degree celsius+ is this too cold?
The compressor in the fridge energises for a constant 30 mins in every 90 mins. Is this normal?
depending on door seals and the number of times the door is opened and the temp setting on the thermostat and the positioning of the fridge it could be considered normal
see if you can get an idea of the cycle times at night when the fridge is not being opened and the room is cooler if the temp setting is close to 32 or zero celsius then the fridge works hard to maintain that low setting but if the setting is higher say 5 degrees celsius it runs a lot easier
the problem with fridges is that every time the door is opened , all the cold air falls on the floor and the motor has to run to fill the fridge with cold air again
fridges that are full of food maintain their cold better than empty fridges
May 04, 2016 | Refrigerators
Why does Siemens KF57U56/16 Freezer works fine, but not fridge?
Check the thermostat adjustment in the fridge section if right up replace the thermostat.
Aug 28, 2014 | Siemens Kitchen Ranges
The fridge is frozen - the temperature guage says 6 degress celsius but everything in the fridge is frozen solid!!
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 30, 2009 | Refrigerators
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
We own a samsung cooltech plus, something, something. The freezer is working fine, but the fridge's temperature suddenly jumped from 3 degrees celsius to 9 degrees celsius. We can't seem to change the...
Im no expert, but you can try this, take the back bottom cover off and you will see two drairn pipes going into a drip tray. remove those pipes ( just pull them down ) make SURE they are not blocked ( there is a rubber thing at the top that can close up--- just cut it open ) place a bucket under those pipes and leave your fridge off and the doors OPEN........ it may take a couple of days for ALL the ice to defrost. when you think its done--- leave it a few hours and if there is any water being collected --- you still have ice in there. i was amazed at how much and for how long water kept dripping out of the fridge drain pipe.... the pipe nearest to the compresser is for the frezzer, If the sensor that tells the fridge to get cold is all iced up it wont even try to get cold--- it thinks it is already.
Dec 18, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
11 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
