Question about Dryers
Dryer squealing and black dust at the back - Dryers
Why is dryer squeaking,belt sprayed but still squeals.
If the belt is to lose it can slip and squeal. worn out belts do the same.
Jul 12, 2014 | Eureka 431BX Bagless Upright Vacuum
How to replace the motor on indesit idc75uk tumble dryer
Black Carbon is Not Good! This could be related to the Brushes on the motor and unless you are good at repairing a motor; I would advise getting a replacement. Write down the Make, Mod. and other details from the Motor label and look on line for a low cost replacement. To open the Dryer, just unscrew the back panel and look for the motor housing. In some cases, you may have to remove the Drum, pulley and/or drive belt. Be careful because the Metal Is Sharp and it can Cut your hands or Arms. The motor when exposed can be removed from the dryer housing by removing the screws/bolts and attached wire connections. Remember the order in witch you took it apart because that is way you put it back together. Remember the exact attachment of the electric wires prior to pulling them off of the motor (Red and Black/or White wires). These wires Must be reattached the exact way they were affixed at the factory. When done, replace the back panel and your done. I do hope you DISCONNECTED the Power Plug "FIRST"...Dah?
Dec 18, 2013 | Indesit Dryers
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
Kenmore 417.90802990 squealing dryer w/ black powdery deposit..
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 20, 2010 | Dryers
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Squealing dryer.
Squealing usually refers to dry bearings. And the only bearings on a dryer that I know of, are where the shaft of the drum attaches to the back. But these seldomly give trouble. Can you tell where in the dryer it's coming from?
Dec 17, 2009 | GE Spacemaker Washer and Dryer Electric...
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
THE DRYER STARTED MAKING A SQUEALING NOISE AND THEN IT STOPPED AND WOULD START AGAIN AND SOMETIMES IT WOULDN'T MAKE A NOISE BUT NOW IT'S SO LOUD THAT YOU CAN'T STAND TO HAVE IT ON.
you may have to take it apart and check two things...
1. the motor on dryers can get pluged with dust and lint and dry out. the motor bearings may simply be dry. it might be too late for the motor, but you could try lubing the motor bearings and at least stop the squeal for a while.
2. remove the drum and lubricate the wheels or bearings that the drum rides on.
lubricate all rollers and belt guides as well.
hope this helps..........jay
Mar 21, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
High pitch squeal
IT IS MORE THAN LIKELY A STUCK DRUM ROLLER OR IDLER PULLEY. I HAVE SEEN IN WORST CASE SCENARIOS WHERE IT HAS BEEN THE MOTOR ITSELF WHEN SUBJUCTED TO LOTS OF LINT AND DUST FROM PLUGGED VENTING. I WOULD CHECK THE FIRST TWO AS THEY ARE THE MOST COMMON. DO NOT OIL THEM.
Dec 28, 2008 | Maytag MDE2600 Electric Dryer
Dryers Logo
13 people viewed this question
Top Dryers Experts
