Question about IBM ThinkCentre Computers & Internet
Boot sequence USB - ThinkCentre IBM Computers & Internet
  • IBM Master
  • 2,219 Answers
Pick f1 to change bios to set to usb permanently.
press f12 to select usb boot on one-off occasion. make sure a usb has not been left in when powered off.
Posted on Jan 21, 2015
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Not booting from usb
In inspiron 2200 shut down the system then restart and when you see the Dell logo tap F2 key. You will goto BIOS. In BIOS go under SYSTEM and then goto BOOT SEQUENCE. Then make sure that USB STORAGE device is at 1. position. You can modifiy this by highlighting the first option and press enter and then use + or - keys to change or look at the very bottom of screen to see how to change the value. Once USB storage device is in first position of boot sequence then on the left hand side of main menu goto POST BEHAVIOUR and expand it. Then goto US emulation and make sure it is enabled (ON) if not then make it on. Then save and exit the BIOS .Now make sure your USB device is connected Then restart the system andsoon as you see the Dell logo tap F12 . Now choose USB from the boot sequence and it will boot form USB device (If that USB device has bootable files)
Nov 09, 2013 | Dell Inspiron 2200 Notebook
How i can boot up win xp on bootable usb on acer travelmate 2413lc
1st of all plug in the usb bootable device. Then:
When you start up your computer it should say something like press f2 or f8 or something for setup. Hold down that key when the computer is starting up then:
1. Search through the BIOS with the arrow keys and enter for the setting to change the boot sequence.
2. Change the boot sequence to have your computer boot from the device first.
3. Then save the changes and reboot your computer.
May 10, 2011 | Acer TravelMate 2300 Notebook
Cannot boot from usb. dell serverPoweredge 2650
Try entering the BIOS (usually by hitting F2 or Delete during the boot up sequence) and looking under the boot menu for the USB drive. Some older systems cannot boot from USB. You might have improperly formatted the USB drive. What are you trying to boot into?
Feb 28, 2011 | Dell PowerEdge 2650 Server
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Ibm not boot from usb
When the system starts up there is usually a key to hit for SETUP, usually ESC, F1, F4, or DEL
Find it, and hit it at the right time.
You will enter the CMOS or BIOS setup.
Once there, locate the BOOT SEQUENCE section and allow a USB boot or external component Boot to be placed int he sequence it it MIGHT work.
Not sure what you're trying to boot from USB for.
Oct 19, 2009 | IBM NetVista M42 PC Desktop
Boots usb first
Hi apicard91
Go into your BIOS and check your boot sequence or boot menu.
there should be a option to disable booting form either a "removable device or external device or usb device"
Just disable that option and then you good...
Please rate the service you recieved
Apr 24, 2009 | Computers & Internet
Boot sequence. I want to boot CD first
No,you don't need to disable quick boot,All you need to change is the boot order.But to boot from CD all you need to do is press F12 while the system is booting up.
Mar 17, 2009 | MSI 865PE Neo2-S Motherboard
I need to know how can I boot from my usb flash thanks
You need to know if your motherboard can do this option.
Enter setup otion generaly when you turn your computer on press the DEL key and you are in the BIOS SETUP configuration. Go to the BOOT SEQUENCE and if it is possible choose USB option.Place this option on the first place with the UP or DOWN keys. For exemple fist boot drive : USB second boot drive HDD ,...
You must format your USB device as SYSTEM ! and have the system installed on it. You can find on the Web a light version of WINDOWS XP called LIGHT to put it on your USB device I think it is an USB flash drive, Is it?
If it is an external HDD you can install the entire system of Windows and boot by it bur select the right boot sequence in the BIOS setup.
Dec 17, 2008 | Computers & Internet
Computers & Internet Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
