Question about Water Heaters
My PE2-52-2 /Ruud water heater is leaking
The heater is still working. The leak is slow. The leakage is at the bottom of the heater.
  • 2976 Answers
SOURCE: Slow leak drips from bottom of 4 year old model
You can probably repair this by removing the fittings and replacing any plastic compression rings with new ones. Everything else can be cleaned with grade "0000" steel wool. This will get rid of any deposits without damaging the surfaces. ! or @ careful wraps of Teflon Tape to the MALE threads will help get a good seal.
Posted on Feb 04, 2009
rylee_smith
  • 8619 Answers
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 07, 2009
  • 10865 Answers
SOURCE: I have water leaking from the bottom of my waterheater PE50T9A
Turn off the electric and drain the tank. Completely remove the exit valve that is leaking and clean up the threads on the valve and in the hole. Get some plumbers dope and dope up the fitting threads and the threads in the hole and then reattach the exit valve. As a real precaution you may consider taking the plastic valve to the hardware store and getting a replacement one. Also dope that one up good.
Posted on Apr 27, 2009
  • 252 Answers
SOURCE: Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
Posted on May 24, 2009
co7196
  • 3433 Answers
SOURCE: My Atwood Hot Water Heater leaks when I turn the pump on.
Where is it coming from? It would make sense to have a plug in the conwe of the tank. Need you to clarify what it is lthat is leajing.
Posted on Jun 15, 2009
Repair a cold water leak at the bottom of my water heater
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
Dec 02, 2014 | Water Water Heaters
Ruud hot water heater
Best thing is to replace it as it might be rusted inside in the bottom
Dec 07, 2013 | Water Heaters
Water meter is ticking away. No sign of water or
If you have a gas hot water heater, water may be dripping onto the baffle plate at the bottom and vaporizing whenever the burner fires. There would be no evidence of water under the heater in this case. Yes, I speak from experience. Also check exterior sill cocks for leakage as one might be open just a tiny bit. If you wait for freezing weather, a leaky sill cock will grow a "beard" of ice.
Oct 30, 2013 | Rheem Water Heaters
Rheemglas water heater leakage from the top seal
1) You have leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
2) I do not know what is meant by 'top seal' since that is not typical water heater part.
Does you product manual show a top seal?
Add comment and describe the top seal and add what it does.
3) Attach a photo.
Dec 31, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Oct 06, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
How to drain ruud pacemaker water heater
Turn off water, turn off power, drain tank:
Copy following link for illustrations
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Aug 26, 2012 | Water Heaters
Hot water heater overflow leak
Copy following link for testing and replacing TP valve.
Do not cap off TP overflow tube, as this leakage signals problem.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Jul 29, 2012 | Water Heaters
My Rhem Ruud G76-200 water heater leaking from below? Can this be repaired?
If it is actually leaking from the bottom of the heater, then it cannot be repaired. Have you looked to see exactly where the water is coming from? Sometimes a leak at the top of the heater, will then leak through the insulation and out the bottom. Another possible source could be from the temperature/pressure relief valve leaking and coming out of the down pipe that goes near the floor or drain. Try to find the source of the leak. It is not practical or safe to repair a tank that is leaking.
Oct 03, 2010 | Rheem Tank Water Heater G76-200, 76 Gallon
Water leaking
Hello All tanks eventauly leak and cannot be repaired.Good thing it is slow!
Apr 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a leak in my water heater coming from around one of the legs. If I shut off the water, the leak seems to change to one of the other legs. Is there some sort of new pan that I can buy or a part that...
Sorry, Sam it sounds like the water heater is defective, unless you can find a leaking connection. It sounds like you have a leak in the heater proper. The reason the leak moves is that, when you isolated the water, it cooled and a slight vacuum is pulled, and the water picked a different course (probably). Before you change the heater out, look at the threaded connections for leakage. Check the inlet and outlet lines, boiler drain valve, pressure relief, and any other threaded connections that you may have. If you find any leakers, you can repair them with wrenches and teflon tape. If no leaks are found at any of the threaded connections, the assumption is that the tank has developed a pinhole leak. They generally are at the bottom 1/3 of the tank. What you can do in the future is to either buy the kind of hetaer that is designed to stir up and remove the scale and sediment in the bottom of your heater, or to manually flush your heater from time to time.
Best regards, --W/D--
Aug 12, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
