Question about LG RUMOR Cellular Phone
Pin code 4 bluetooth
I found my older bluetooth and I have a rumor lg I got the bluetooth 2 show up on tha phone but I neet a pin code?
0000 or 8888
Posted on May 26, 2009
  • 25 Answers
Try 0000 or 1234. They are the common Bluetooth passcodes.
Posted on May 21, 2009
How do i turn on bluetooth feature on my rumor 2
    • 1 Turn on the Bluetooth-enabled device and enable it to be in "Discovery" mode. Check the owner's manual of the device to learn how to put it in "Discovery" mode.
    • 2 Press "Menu/Ok" on the LG Rumor2, which is the middle button on the phone.
    • 3 Press " * " to access the settings menu.
    • 4 Press "1" for the Connections menu.
    • 5 Press "2" for the Bluetooth menu then press "1." Press "Yes" when prompted to turn on the Bluetooth feature. A list of available devices appears in the menu.
    • 6 Highlight the listed device, which should be showing.
    • 7 Click "Ok."
    • 8 Enter the passkey provided in the owner's manual of the Bluetooth device. The standard passkey is "0000." The Rumor2 is now paired with the Bluetooth device.
    • 9 Press the "Call" key on the phone or the "Call" button on the Bluetooth device to answer calls through a Bluetooth headset while paired.
Mar 01, 2012 | LG Rumor 2 Cell Phone
How do i turn the bluetooth feature on for my rumor 2
  • Insert a microSD card into the slot on the right side of the phone.
  • 2 Connect the phone to your desktop with the USB cable.
  • 3 Select "Transfer Music" on the phone by pressing the "OK" key after highlighting "1 Yes" on the display.
  • 4 Go to your desktop and use Windows Explorer, which will have now opened up, and you can drag and drop files from the desktop to the phone just like another directory.
Use the Rumor Bluetooth to Connect to Your PC or Other Bluetooth Device
  • 1 Set your secondary Bluetooth device into the pairing mode.
  • 2 Open the "Tools" menu on your phone by first making sure it is in the standby mode and the slide is closed. then press the "OK" key and select "Tools."
  • 3 Select "Bluetooth" and press the "OK" key to choose "Pair with Hands-Free." If "Bluetooth Wireless Technology" is turned off follow the prompts to turn it on by pressing the "Left Soft Key."
  • 4 Highlight secondary Bluetooth device on the list of found devices and press the "OK" key.
  • 5 Enter "0000" pin code and press the "OK" key to initiate the pairing process.
  • 6 Enter the device's name and press the "Left Soft Key" for "Save."
  • 7 Connect to your device by pressing the "Left Soft Key."
My LG Rumor 2 is block with a 4 number security code that my daughter wrote and does not remember, how can I unblock it.
once i faced a similar problem with my motorola mobil. i got it to a mobile service expert and he used some software and found it out. some experts flash the phone and restore the phone to factory conditions. these are the options.
Nov 04, 2010 | LG Rumor 2 Cell Phone
How to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
Oct 25, 2009 | LG RUMOR Cellular Phone
Difficulty pairing bluetooth to lg rumor phone
I had this problem with my LG Shine. I took the battery out, put it back in, and turned it back on. It worked!
Sep 05, 2009 | LG RUMOR Cellular Phone
Motorola H715 not connecting with my LG Rumor
Do this:
Turn the headset off.
Set your rumor to find new devices, then immediately turn the headset back on. The devices should pair together. If the rumor asks for a code, the code is 0000.
Mar 12, 2009 | LG Rumor LX260 Cellular Phone
Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
Feb 28, 2009 | Motorola Mobility H500 Wireless Headset
Trying to bluetooth ring tones from motokrzr to lg rumor?
Bluetooth technology is still fairly new and it make take a few attempts to connect. Keep in mind some phones, like most Samsungs still use an older version of bluetooth software which only pairs with audio devices. So, best I can suggest is do a power cycle (remove the battery and let it sit for a few seconds and try again) to make sure there is no software loop errors that occur time to time and keep trying. If you still don't have much luck, go ahead and repost and I'll test it with some phones at the other shop and see what I can get.
Nov 16, 2008 | LG RUMOR Cellular Phone
LG envy Bluetooth
sorry you cant as Verizon blocked this feature for some reason, though you can get the file off of the phone on to a computer and then send it to the rumor via bluetooth.
Aug 14, 2008 | LG enV VX9900 Cellular Phone
I have a LG rumor cell phone and a motorola H700 bluetooth headset im trying to figure out how to pair them up
Somewhere in your phone you will find SETTINGS, then CONNECTIONS, then BLUETOOTH, then SETUP. Turn the Bluetooth on, hold the on button until you hear a long beep. The bluetooth is ready to merge with your phone. Now go through all those other steps and have the phone find the bluetooth. the phone is now asking for the CODE#, it is probably 0000. Unless you have the instructions and they show a different code#. If you are having trouble after that with the code # try the last 4 digits of your telephone #..
Jul 27, 2008 | LG Cell Phones
LG RUMOR Cellular Phone Logo
367 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
