Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalogIn such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
