Question about Bosch sensixx TDA 8333 Iron
Reset button homedics overheat - Bosch sensixx TDA 8333 Iron
Use Manual Garment Steamer Model PS-300
If you have the Home Pro Professional Garment Steamer PS-300 from Homedics, the Homedics website has the manual on their support page. Go to http://www.homedics.com.ph/instructionbooks/ .
then use the drop down menu to select the PS-300. Click on Download to get the instruction book. Note: the file is a PDF, so you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Jan 20, 2014 | Irons
Iron with auto shut off will not restart, why?
The thermostat is the problem, I used aew3656's solution posted elsewhere, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW dont forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 25, 2010 | Homedics PS-200 Iron with Auto Shut-off
PS-200 Iron with Auto Shut-off: Can you really fix problems with a steamer? Is ...
The thermostat is the problem, I used aew3656's solution posted elsewhere in FixYa, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW don't forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 16, 2010 | Homedics PS-200 Iron with Auto Shut-off
No steam coming out
Is the red overheat warning ligth on? if so, press the reset button, that should reset the thermostat and make it work again.
Mar 13, 2010 | Homedics PS-200 Iron with Auto Shut-off
Plugged in, reset button is lit, won't go off
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
Apr 20, 2009 | Homedics PS-200 Iron with Auto Shut-off
Leaks Rust!
You either have a lot of iron in your water or you bought a used iron. Eitherr way, run a mix of 15% wite vinegar to 75% water. use it until gone and refill with plain water and run that through. Try using distilled or filtered water.
Feb 01, 2009 | Homedics PS-200 Iron with Auto Shut-off
Replacement parts for homedics ps-200 steamer
I'm looking for same thing.
Jan 09, 2009 | Irons
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Bosch sensixx TDA 8333 Iron Logo
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
Mark Chaney
Mark Chaney
matt
matt
Are you a Bosch Iron Expert? Answer questions, earn points and help others
