No response from washer - what should I do?
My Maytag washin machine (10 years old, top loading) all of a sudden doesn't do anything - as if there is no power connection. Checked the power outlet and there is power there. What could be the reason. Thanks
  • wannabehandy May 21, 2009
    Thanks for your suggestion. However, my Washer doesn't have the fuse box at the top console. My washer Model number is LAT8426AAE.
    Any idea where the fuse box could be.
    Thanks
    Problem Solver:
  • 9 Answers
There is a fuse located at the top console of washer. replace fuse and you should have it running again.
Posted on May 21, 2009
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Our 7 year old maytag washer won't aggatate , is this worth fixing?
Only you can answer that. The belt costs about $10 and a new machine costs from $400. If the transmission is out, thet can be purchased for about $100.
Dec 28, 2009 | Maytag MAV2755A Top Load Washer
Leaking maytag
it could be the pump but there is a seal in the tube where the transmissin goes through the tub that seal has a common problem of leaking but if it 10 years old i would replace the machine
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag A108 27 years old
It sound like Transmission Problems,Bury it and give it a Decent Burial, Dont Forget to Give Thanx.....ttech
Jul 23, 2007 | Maytag SAV5701A Top Load Washer
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washin machine not spinning
Your repairman is correct. The problem is a rusted spin bearing just under the tub. It is only in use during the spin cycle. Parts are about 50-70 bucks but it's a very difficult job and out of the range of the average do-it-yourselfer. Try to use the machine almost every day to prevent the bearing from freezing up. That way you can get a few more months use out of it before replacing it. If it does freeze up, try to turn the basket manually. It won't move much when its stopped because of the brake. Your repairman probably turned it during the spin cycle by defeating the lid switch.
Nov 06, 2006 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
