Question about Lite Cruiser Saltwater Electric Trailer Winch
Trac lite cruiser winch slips - Lite Cruiser Saltwater Electric Trailer Winch
    Sergeant:
  • 268 Answers
That happens when winching something to heavy for it. On that type of winch gets damaged to bad then its cheaper to replace with better one.
Posted on May 02, 2014
The special rod will not raise tire.Under load the rod mechanism slips from winch connection.What can I do?
try one that has the same or better end also try lifting tire up while turning and you can lower in down and lubercate it with spray lube and try again
Sep 30, 2014 | Cars & Trucks
2001 PT Cruiser,Trac off lite & Brake come on and off. everything checks OK and replaced Computer Module.
'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar.
Traded in '02 Silver Touring Edition w/87,000 miles
Jul 26, 2012 | Chrysler PT Cruiser Cars & Trucks
2001 pt,abs &trac lite come on car hesitates sometimes dies,in a garage & they cant find the problem
I have a 01 pt that did the same thing. By you're exhaust manifold there is a thick wire set with loom over it. Pull it back and check the orange wire. It controls the crankshaft Senor mine was burnt through. Easy fix black tape and a price of wire, spliced it together and was good to go. But I relocated the wire off my exhaust
Jul 17, 2012 | 2001 Chrysler PT Cruiser
Snow Bear Winch..... Will not pick up plow at times. Motor seems strong drum will not turn,,,slips. Is there a replacement part available without buying an entire winch? Thanks
Hi there, I had the same problem, my winch has a chain to lift the plow.I put oil on the chain to keep from rusting and thats what started my troubles.So I took the mount off that holds the chain on the winch and there's a brass piece that is squeezed behind it.Cleaned and tightened it and works fine now. If you take motor off winch to check gears[ DON'T USE GREASE] when reassembling! When its cold it doesn't want to turn, just use motor oil or spray lube
Jan 19, 2011 | 82" TruckSUV Snow Plow
FJ cruiser issue
I had the same thing happen yesterday. I took it to the dealer, and they said the Catalytic Converter was bad and they needed to order a new one. You should take it to the dealer.
Jun 17, 2010 | 2007 Toyota FJ Cruiser
2001 pt cruiser (TRAC button )
the Trac button disengages the Traction Control System. I think some engineer installed this button specifically for teenage boys. I would keep the traction button on as it will help you in bad weather to reduce the chance of wheel spin.
Jan 10, 2009 | 2001 Chrysler PT Cruiser
Shaking with engine light and VSC Off lights turned on
If just found this on another forum:
A few days ago I started the Cruiser and had 4 indicators stay lit.
They were the CHECK ENGINE...SLIP INDICATOR..VSC TRAC..VSC OFF.
Didnt noticed any change in driving and 4-wheel drive is still working.
I removed the negative cable from the battery and the same indicator lights have NOT come back. Everything is back to normal as far as warning lights go. Should I take it in to the service center and have it checked.
Or should I wait to take it in, if it does it again?
Aug 16, 2008 | 2007 Toyota FJ Cruiser
Lite Cruiser Saltwater Electric Trailer Winch Logo
96 people viewed this question
Top Trac Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Trac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
