Sharp SC 9850 AV
SOUND
Panasonic soundbar SC-HTB8 is paired to Bluetooth but won't play the sound from the connected TV, is there anything we can do. TheTV is a Panasonic smart tv & we have connected it with a optical lead
If you have connected the optical cable then you should be able to select AV using the TV remote, keep pressing until you hear sound from soundbar!
Dec 28, 2014 | Audio Players & Recorders
I WANT TO KNOW HOW TO CONNECT MY PANASONIC MODEL SC-HT830V HOME THEATER SOUND SYSTEM TO A SHARP AQUOS MODEL LC-37D62U TELEVISION I NEED A WIRING DIAGRAM
U do not need a diagram-simply hook up red/white wires from audio output of sharp tv to audio input(tv) of panasonic unit.any questions contact us- djstvrepair@comcast.net
Sep 10, 2009 | Televison & Video
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Nov 06, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
No sound during playback
you need to check whether sound is ok tru av out leads ,or is it problem with no sound while trying to play back in camera as have seen a few of these with internal speakers going faulty.if you try it tru av leads you should have sound if this is the case
May 09, 2007 | Samsung SC-L906 Camcorder
 Grubhead
Grubhead
