Question about Refrigerators
Frigidaire display doesn't function
Frigidaire LGUB2642lF3 display board doesn't function at all, No power to the unit.
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
ngafm
  • 166 Answers
SOURCE: Frigidaire - GLTF2940FS0 -LOC message on display
Peace,
ngafm at your service,
With an error code or loc message the only way to find and to repair this is,
First unplug the washer and wait a ten minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 08, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
  • 126 Answers
SOURCE: Model FCD-123 Frigidaire malfunction
2 possible issues .evaporator fan motor is not working.you should be able to hear it in freezer.auto defrost is not working and vents are clogged with ice.look for ice/frost buildup on freezer wall///floor
Posted on Jun 25, 2009
  • 1531 Answers
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Posted on Sep 17, 2009
Why is my Frigidaire 18,000 BTU A/C (FAM186R2A2) not coming on?
Hey friend, thank you for your inquiry!
I see you have recently changed the PC board inside of your Frigidaire air conditioner, FAM186R2A2, and now your appliance will not come on. It sounds like you could be having a potential issue within your power cord or another issue within that board. I would recommend having a professional come out to diagnose your appliance to avoid any further unnecessary part purchases. Hopefully this is helpful. -Matt
Aug 26, 2014 | Frigidaire Heating & Cooling
NO WATER AT WATER DISPENSOR ON MY FRIGIDAIRE LGUB2642LF3
Hi Ernest Jackson - First, I suggest checking that the water valve is completely open (usually located on the back of the unit). Second, when was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. Also keep in mind that a clogged water filter or a blocked supply water valve may also lead to no water to the dispenser. If that is not the issue, than the refrigerator could possibly have a faulty valve, dispenser control board and/or failed water valve diode. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Mar 07, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire front loading washer, letter J in the display, will not operate.
First I recommend unplugging the washer for a couple of minutes then turning it back on. If that doesn't clear it unfortunately your are going to have to replace the control board. You can find the part here
http://www.repairclinic.com/ Just use your model number to look it up.
Oct 27, 2012 | Frigidaire Washing Machines
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
Pgp368gsc frigidaire stove clock will not light up after power surge. Able to reset time but clock doesn't stay lit.
From what you have described, seems the power surge has damaged the control board inside of your unit. Now you would need a service technician to install the part, but depending on how old the unit is will depict how you can go about purhcasing the control board part, or possible have it covered under warranty ( all depends on the age of the unit ).
You may contact me directly with you and your unit's information and I can further research what your next steps should be.
Kindly,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances, North America
Chris.Polk@Electrolux.com
Jun 25, 2011 | Frigidaire Gallery 30" Self-Cleaning...
My HK 3380 doesn`t turn on...
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
Mar 22, 2010 | Harman Kardon HK 3380 Receiver
Display Panel Not Working
Only thing is check to make sure clock control is getting 120 volts into the l1 connector on the board. If it is make sure the ribbon cable is plugged into the board properly. If it is replace board.
Mar 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
DISPLAY ON FRIGERDARE STOVE DOES NOT WORK
HI. Kindly unplug the unit for five minutes. Once the five minutes are up, simply re-connect power to the unit, and try to start a baking cycle. If the display continues to not function, this will confirm that the main control board has failed.
This type of failure will require you to replace this damaged control board, asap.
Dec 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
May 27, 2009 | Frigidaire Dishwashers
My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Nov 10, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
