Question about Toshiba Satellite A15-S157 Notebook
Wireless connection problem
I am using WinXP Pro SP2 on my Toshiba which I bough second hand a couple of weeks ago. The problem is that it does not navigate interent when using my wireless connection. The connection shows excellent signals and connection. When I directly type in a webpage address in address bar, it connects to that page immediately. However, it does not go any further from that page e.g. no searches or next page etc. However, if I type the next page's address directly it goes there. When I use my ethernet cable with Toshibsa, there is no problem whatsoever in navigation. I tried following solutions
1) Uninstall and install network and wireless cards with latest drivers
2) Format and re-install Win XP
I do not have the recovery CDs so I am desperate to solve the problem.
  • mabuamin Aug 31, 2008
  • 778 Answers
I would check your wireless configuration utility's security settings (Windows, Toshiba's, whichever you are using) and see if you can find something there that would prevent you from hot linking (sounds to me like what the problem is). I personally always use Windows zero configuration wireless utility, mainly because it's already there and I've had problems with third party utilities conflicting with it. I feel pretty certain that it's a security issue with your wireless utility though, so give it a check and let us know.
Good Luck.
Posted on Feb 24, 2008
Disconnectivity within 1 minute I install a fresh
Try using the manufacturers drivers for wireless lan and lan.
Jun 10, 2017 | Computers & Internet
Running winxp pro and installed d-link DWL-G122 adaptor. Everything OK for about 1 week. Now the adaptor will not show up in the "network connections" window but it does show up on device manager. the...
Uninstall any and all "Norton" application from your computer using the "Norton uninstaller". Then reinstall the network adapter drivers.
The norton firewall causes a HUGE LOT of problems to the network adapters.
Get another security solution, other than any "norton" product.
Nov 03, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Toshiba Tecra M2vS330- crashes when wireless card switched to "on
Hi, your problem does not have to see with the openoffice that download, It coincides with your card mini - pci wireless I damage, and is for it that whenever you ignite the wireless your Laptop restarts for hardware malfunction. the solution is to replace the mini wireless board.
Jan 09, 2009 | Toshiba Tecra M2V-S330 Notebook
IBM cannot detect my wireless connection
maybe you can set youre Wifi on port 11 thats a standard and you will be able to conect on youre network.
Gr Rich
Jan 08, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless fails to work after reinstalling XP SP2
Hey there,
The wireless driver might only work on Vista, try the IT Administrators - Intel® PROSet/Wireless WiFi Connection Utility for Windows* XP and Windows Vista*from here
First uninstall the one you have though..
Hope this helps
Chris (ziraffa)
Sep 10, 2008 | Intel PRO/Wireless 3945ABG Network...
Satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
My laptop cant find the card
is your card connected proper if so l would say its faulty now
Mar 03, 2008 | Intel PRO/Wireless 2100 MiniPCI 802.11b
All needed drivers for WinXp.
The Toshiba website had directions for getting drivers. You will need to provide your model number and follow links to get help. Good luck
Feb 18, 2008 | Toshiba Satellite A135 Notebook
A couple of things you can try:
1. Set static IP address on your WiFi Card including your ISP's DNS;
2. In your browser, go to Tools, Options, Advanced, Setting and check/tick "Auto-detect Proxy settings for this connection"
3.  If you have  the option to Use HTTP 1.1 through proxy connections, check/tick that also;
4. Right click on your WiFi networking icon and click on repair;
5. Google, download & merge to your registry "" which is a patch for Win 2k/XP not to cache failed DNS entries.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Oct 21, 2007 | Toshiba Satellite A15-S157 Notebook
Vaio laptop VGN-BX540B user
you should only need to enter the WEP key and get youre friend to remove your mac address. You may also need to refresh the ip address of your wireless card, so go to control panel>network connections>right click to properties>TCP/IP line>properties and ensure 'obtain ip address automatically' is ticked, then reastart your pc. Or you can also click Start>Run, then type ipconfig /flushdns, so as to renew your dns and ip address.
Aug 22, 2007 | Dell Inspiron 6400 Notebook
Toshiba Satellite A15-S157 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
