Aiwa cd player repair - Audio Players & Recorders
3 Suggested Answers
SOURCE: i have an aiwa nsx 5200 mini system the cd player broke
Soooooooo many people have complained about this system not reading discs properly, yet the solution is incredibly simple. All you need to do is calibrate the lens, and you can do this without even opening the stereo! Here's how:
With the stereo all unplugged, turn it around so the back is facing you.
Now use a flashlight and, looking through the grating on the back, approximate where you think the cd lens mechanism would be. You should see 2 8-pin connector wires side by side (one red and one white) and to their right a small black circle screw type thing.
Using a screw driver, turn the screw thing about 1/10 of a revolution clockwise.
Plug in, and test with a clean cd. If nothing happened, repeat the procedure turning the screw thing in tiny increments (don't over do it.) Eventually, the cd player should recognise the cd. Keep fine tuning and testing until you've found the "sweet spot" where it recognizes and plays cds optimally.
Overall, you should NOT have to turn any more than a full revolution, and even half a revolution is pushing it. What you are really doing by turning this screw is fine tuning the "data reading point" of the laser. Too close and it will focus on the area between the cd and the lens, causing failure to recognize the disc. Too far and it will focus past the data perhaps recognizing the disc but not being able to read it. I believe the major problem with these players is that as they settle in, the area between the lens and cd changes. This would cause a gradual degrading in performance until the player finally failed to recognise any data at all (which is exactly how mine went personally.) There isnt a problem with the quality of the lens itself, therefore it is very fixable!
I have heard that all 3cd Aiwa Mini-systems share this problem so, as long as the calibration tuning screw is exposed through the grating on the back, this fix should work for any of the Aiwa mini-systems with this particular problem. If the screw isnt exposed, it is still possible to get at by opening and dismantling the player. (Unfortunately, i did not originally notice that the screw was accesible through the grating, so i went about pulling the entire system apart and wasting hours of my life. You can thank me later for saving you this tedious trouble as you're listening to cds on your newly fixed player ;-) )
If this doesn't work, or doesn't fix the problem completely, try cleaning the lens. You can do this by either by using a cd lens cleaner (looks like a cd with a brush built into it) or opening up the stereo and using a soft cloth on the lens. You may also want to try putting the screw back to its starting point and using the same procedure but turning the screw counter-clockwise. (I personally had to turn clockwise but who knows, maybe your player settled in differently.)
As for the mechanism itself, i have no idea. I did notice, however, that the lifting mechanism sometimes picks the cd up off-centered causing failure to play. You can semi-fix this by holding the stereo at an angle while it picks up the cd or placing it off-centered in the tray. Its annoying, but it works :)
Posted on Jan 03, 2009
welcomejee
  • 10594 Answers
SOURCE: Replacement CD unit Sanyo A1346229 for Aiwa Music
What is part description of Aiwa part number S1540028000
It is optical block unit, I need to know is its description as is it KSS-310 or KSS-210 etc
Part description would be written on little sticker pasted in part itself.
Thanks.
Posted on Sep 14, 2010
Cd wrongly inserted in an AIWA CA-DW935M is stuck in the cd player, wants to get it ejected
I was able to find the manual for that model, which included a series of tests for the CD trays. Perhaps if you ran through them you will be able to get your CD out. If not, please ask for additional help.
AIWA CA DW935M Service Manual free download schematics eeprom repair...
Feb 09, 2014 | Audio Players & Recorders
I have an Aiwa stereo cd player that only plays certain cd's but not the new ones, it is model cs-na222
Some Aiwa players will not play burned, non-closed or expanded limit cds (CD of 700MB or overburned to 750MB).
When you say new cds do you mean purchased pressed cds or ones you created?
Jun 03, 2010 | Aiwa Audio Players & Recorders
My cd player keeps saying error 3 what does that
its because of data memory corrupt.. u might need to flast your memory of ur cd player
May 28, 2010 | Aiwa CDC-MP3 CD Player
AIWA CXNMT 520 CD/TAPE/RADIO PLAYER
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Thanks.
Dec 18, 2009 | Cameras
Aiwa 3CD changer,Model no.CX-NK550HR, CD Player not working.CD Board is required to be renewed.Where can I get original CD board of above mentioned model
some one help me...my aiwa vcd component model no. CX-NK550HR suddenly dont open or power up... i think it have a problem in its transformer...what do u think???kindly send me a response on my problem pls.....
ym:jhongojar
email add; near.evil@yahoo.com
Nov 12, 2009 | Aiwa Audio Players & Recorders
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
HOME STEREO SYSTEM CD PLAYER
I WOULD LIKE TO KNOW WHY AFTER PAYING WHAT I DID FOR YOUR ENTERTAINMENT CENTER THAT I WOULD HAVE TO PAY FOR THE REPAIR SERVICE PLAN?????? THAT JUST DOESN'T SEEM FAIR AT ALL TO THE CONSUMER. I WOULD LIKE THE EMAIL ADDRESS TO SOMEONE OF SUPVISOR POSITION. THANK YOU
INSTEAD OF CLOSING THE CD LOADER WITH THE OPEN/CLOSE BUTTON SIMPLY CLOSED IT BY CHOOSING THE TRACT NUMBER WANTING TO PLAY. SO FAR IT HAS WORKED. BUT WILL NOT WORK AUTOMATICALLY WILL TRY PROGM. THE REMOTE NEXT SEE IF THERE IS ANY LUCK WITH THAT PART.
THANK YOU
Jul 06, 2008 | Aiwa NSX-A115 Shelf System
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
50 people viewed this question
 Grubhead
Grubhead
