Question about Samsung SGH-E840 Smartphone
Solve this i want to instal update of the software in my phone now
Hi, how can i flash firmware on my huawei phone using USB? any program? and, i cannot find any firmware file on internet or sites...help please :(
Please.
If you have any problem with any electronic device, DON'T try to solve this with a software update.
All updates have the same restrictions.
The system must have enough power to load and install the update (power cord is the best) and all systems should be working without any flaw. As soon as something is wrong, you can't be sure the update is loaded correct in the memory and installed.
Most factories, only release updates when they discover lots of bugs in the software. Providing the firmware comes with more warnings then I already gave.
If Huawei did not release any update, you can't find it anyway.
It proves the software does not cause problems.
If resetting the phone, does not solve the problem, you should contact a certified service centre.
Jul 16, 2014 | Huawei G7010 - Black Unlocked Touch Screen...
Bluetooth shows unable to perform operation n73 can't switch on bluetooth
A software update can be solve your problem. Go to the nokia website and download the nokia software update from the nokia website then install the software on your pc then connect it with your mobile then on the software updater on the compter select your phones name then accept the agreement then they wil update your phones software, and your bluetooth is ok now
Jun 18, 2011 | Nokia N73 Cellular Phone
How to install software in nokia 5220xpress music when the software is failure in a nokia mobile
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Mar 20, 2011 | Nokia 5220 XpressMusic Cellular Phone
I have download game application, I have played it without problem. after that my phone -Nokia X3- stop working suddenly !! when i try to run it , it display nokia logo then the screen get white for 3...
Thank You
Feb 09, 2011 | Nokia X3 Cell Phone
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
Nokia6300automaticswitchoff
hi dear. hope this solution will solve ur problem. In most cases this happened because of software problem. Kindly update ur firmware to solve this issue. go to this link http://mea.nokia.com/support/download-software/device-software-update and select ur device which is Nokia 6300 and then download this Nokia Software Updater software. install it on ur pc and connect ur phone with PC via data cable. then update ur phone and i hope ur problem ill b solved.
Oct 15, 2010 | Nokia 6300 Cell Phone
Can't open musicplayer
Its general Software problem in Nokia 3110. I have solved this problem more than 100 times. First try to update software by Nokia software update. If problem continue then Re-install phone software. Your problem will solve 100%.
Thanks.
Happy to help you.
Apr 24, 2010 | Nokia 3110 Cellular Phone
I WANT TO UPDATE MY LG KF600 MOBILE INTERNAL SOFTWARE UPDATE WHAT SHOULD I DO AS THE OLDER ONE IS POWER CONSUMING ALSO NOT INSTALLING INTERNAE SETTINGS SAYING MEMORY IS FULL, i have reset my phone many...
connect the phone to your PC. and open the phone software and then find a option inside that to update your phone software. generally all the phone softwares have it. while doing that make sure you dont disconnect the phone during installation.
Aug 03, 2009 | LG KF600 3MP InteractPad Triband Phone...
How to update software for k790i
www.sonyericsson.com/.../faultyphoneasoftwareupdatemaysolveit/k790i?...
f your phone freezes, hangs up unexpectedly, vibrates continuously or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version. You can update software quickly and easily with the Update Service; the application checks for new software for your phone and automatically installs it.
Jun 21, 2009 | Sony Ericsson K790i Cellular Phone
Updating N95 Software
Make sure to update your Nokia Suite application before updating.
I recall there being an issue when updated the phone software with the steps being Backup to your PC, Update software and Restore from your PC but since the update changes some of the phones software the older Nokia Suite was no longer compatible and came back with an error.
If you can, I also suggest running a backup to your memory card, you can never have enough backups when upgrading these phones.
Jan 25, 2008 | Nokia N95 Cellular Phone
Samsung SGH-E840 Smartphone Logo
161 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
