Question about Frigidaire FDR30S1 Dehumidifier
Have a DR30S1 where the power light only flashes and the unit fails to power up at all
Electrolux EXD15DN3W dehumidifier has power to unit, but wont start operation? Display is off, on button doesnt respond, but LEDs light and beeps when bucket is removed. Any advice much appreciated.
The bucket interlock may be defective. It works correctly to signal when the bucket is removed but doesn't signal the power switch that the bucket is in place.
Nov 23, 2016 | Dehumidifiers
Why does the power light on my dehumidifier flash quickly?
without the model number I cant be 100% sure , but due to your description of the last thing u did , Id say the light is flashing indicating that the water catch bucket is not installed correctly back as it was before , most units have a safety that wont allow a unit to operate unless the water catch bucket is installed and M/T as this would allow it to dump water to the floor if it were not
Nov 24, 2015 | Dehumidifiers
I have a FAD 704 DWD, does it not have a power on light? I called for a question regarding a different issue and the service tech said it was very bad to not have the on light "on".
Thank you for your inquiry, Lisa Cooper!
I understand that the power light on your Frigidaire dehumidifier is not showing you the power light is on. It sounds like you could have an issue with your control panel. If your dehumidifier is running it could be that the light has failed. If you have a current warranty I would reach out to your manufacturer to see if they have a resolution for such an issue. Hopefully this helps. -Matt
Nov 17, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
Power light flashing on danby dehumidifier won't work
As I tell most folks who complain about the problem you're having
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter. To remove the filter on your model it will either have a pullout tab on
the right side of the unit, behind the louvers on the front. Or remove the bucket and the filter
frame will be just on the inside top of the opening behind the front louvers.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 25, 2011 | Danby DDR2504 Dehumidifier
It does not turn on. The power light flashes on & off.
Probably a condensator that's busted on the power section of the electronics board, or a broken IC chip in the same section. The best thing to do would be to bring it to a technician to get it checked out. If it's just a condensator, get it fixed cause it shouldn't cost a fortune, if its an IC chip, most of the time it's cheaper to just buy a new unit.
Jul 07, 2009 | Daewoo DHC250 Dehumidifier
Power lose
I have a 45 pint. I have to slide the bucket in and out of the unit multiple times. Make sure to wait a few seconds after each time to see if it will recognize no water (sometimes the red light comes on, but then changes it mind). Also, I've found that leaving the bucket a little crooked will make it respond. It sucks, I know. Mine is only a year old too. Should not be a problem like this!
Sep 14, 2007 | Frigidaire FDL45P1 Dehumidifier
No lights on control panel. Plug is powered.
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
Sep 19, 2006 | Haier HDN655E Dehumidifier
Frigidaire FDR30S1 Dehumidifier Logo
29 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
