Question about Microsoft MS Windows XP Professional SP2
Startup Windows XP
I start Windows XP Professional SP2 when the screen appear window XP loadding Screen I want to add my name in that Screen . How can i do that ?
I hope that is not possible but if possible suggest me ?
  • 519 Answers
It is possible to change your start up screen. Here is a link to the trial software necessary to do this:
http://www.softpedia.com/get/Tweak/System-Tweak/BootXP.shtml
The application is called Bootxp and can be used to change your boot screen to whatever you like.
Best wishes,
Graemevm
Posted on May 21, 2009
    Scholar:
  • 106 Answers
You can't add your name to the boot screen, the closes you're gonna get is, You can download Bootskin and you can change that boring xp intro =)
Good luck =)
Windows does not displayed after boot, just "black screen".
Next time that you start windows, hold down the left shift key, that should prevent programs from starting automatically as windows boots. If the computer then operates normally, then take a look at your startup list (use msconfig). Otherwise...
Try starting in safe mode, see if problem still exists. If it does, something is going on with core windows system files. If not, then a program (which automatically starts) or driver is causing the issue.
In either case, you can also start in safe mode, but a version that prompts you if you want to load every file (and there are a bunch of them). The last file that is loaded before problem appears is usually the culprit.
Good Luck.
Jun 19, 2010 | Microsoft Windows XP Professional SP2
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
      Add installation to boot list? (Yes/No/All)
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Apr 13, 2010 | Computers & Internet
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
Missing boot.ini cant find it and missing logon.exe
      [1] C:\Windows
Oct 03, 2009 | Acer Aspire One PC Notebook
Explorer.exe Application error in Windows XP Professional SP2
hello ! what you should do put another HD then install XP the reason for this messages could be due to registry .
if you are getting the same messeges get another cd of XP
GOOD DAY
May 27, 2009 | Microsoft Windows XP Professional
Start Menu Picture Disappeared Suddenly
Turn the Welcome screen on or off It sounds as if you accidentally turned off the welcome screen. Here's how to turn that function on and off:
To turn the Welcome screen on or off
You must have a computer administrator account on a computer that is a member of a workgroup or is a stand-alone computer to turn on or turn off the Use the Welcome screen feature. Logging on at the Welcome screen is not available on computers that are members of a network domain.
  1. Open shortcutcold.gifUser Accounts in Control Panel.
  2. Click Change the way users log on or off.
  3. Do one of the following:
    • To specify that users log on to the computer using the Welcome screen, select the Use the Welcome screen check box. A user logs on to the computer by clicking his or her user account name on the Welcome screen. If a password is assigned to the account, the user is prompted to type it.
    • To specify that users log on to the computer without using the Welcome screen, clear the Use the Welcome screen check box. The Welcome screen will no longer appear when you start the computer. To log on to the computer, type your user name (and password, if you have one) in the standard Log On to Windows dialog box.
note.gif Notes
  • To open User Accounts, click Start, click Control Panel, and then click User Accounts.
  • Fast User Switching is available only when the Welcome screen is turned on. For more information, click Related Topics.
I hope this helps. Please let me know if you require further assistance.
Feb 26, 2009 | Microsoft Windows XP Professional SP2
This could be a memory problem or a problem with the OS (XP). If you can boot the original XP CD like your doing an install then it's not a memory problem more the likely. Can you boot your XP CD?
Nov 27, 2008 | Microsoft Windows XP Professional
Hello
the black screen at windows startup implies that u have a probleme with ur software package(service pack 2)
so get a fresh copy of the softwares u have mentioned
then 1st install windows serice pack 2 from the bootable disk
after that when windows starts install ms office professional.
below is the link to download windows xp sp2 and ms office2007 professional(better u use opera 9.25 version or higher version for download)
For windows xp sp 2-
http://www.mininova.org/get/1178630
For ms office proffesional-
http://dl.torrentreactor.net/download.php?id=1406943&name=MS+Office+2007+Professional+Plus+%2B+Expression+Web
after downloading xp sp2 ,burn it on disc using nero and then install from cd
Feb 27, 2008 | Microsoft Office XP Professional + Service...
Microsoft MS Windows XP Professional SP2 Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
