Question about Garden Treasures 41000 BTU Stainless Steel Liquid Propane Patio Heater
My heater lights up but then turns off after a few minutes
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
Mar 04, 2016 | Duraflame Powerheat 1500W Infrared Quartz...
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving.
If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner.
Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light.
Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position.
Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear.
Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear.
If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock.
If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Nov 05, 2014 | Patio Heaters
Patio Heater Garden Sun model JDS04SS After lighting the jets all lightup but within minutes only half the jets stay alight. Is this dangerous? the heater is a couple of years old.Can it be repaired and...
Your heater needs to be cleaned & adjusted. Contact your gas supplier for information, as to do they do the service or have someone they recommend. You will probably have to bring it in.
Oct 22, 2014 | Patio Heaters
Heater Shuts Off after 2-3 minutes
Does it matter if the thermostat is 120v or 250v?
Jan 31, 2014 | Lifesmart Renew Infrared Quartz Heater...
My propane outdoor heater lights and generates heat on low but when i turn control to high the flame and heat do not increase
The troubleshooting manual says low fuel, low fuel and cold weather and kinked supply line. Beyond this I would need to know if something happened to the unit like it fell over or was taken apart. Best, Joe 1_31_2014_3_36_44_pm.png
Jan 26, 2014 | Patio Heaters
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
A ERR comes up on my American comfort heater
Remove power for some time and switch on after few hours , this might reset any error on the processor , if not the error could be due to fault indication of a failure within the heater, could be the infra or the element.
Oct 02, 2013 | AMERICAN COMFORT ACW0035WE 1500W Infrared...
I have 2 sunjoy G-PH001PSS, when attached to the propoane tank, th unit does not light. I do not hear any gas whe turn the control knob to the on position. When i remove the gas line from the heater the...
Greg...
The lighting PROCESS involves HOLDING that
"PRESS MODE" for QUITE a (long) WHILE...
To clear the AIR out of your fuel line...
I have seen ... Up to 5 minutes
although I believe that is excessive)...
It is MOST LIKELY your troubles are procedural.
(READ the manuals)
ELSE
Blue Rhino
is the place to START ... or SEARCH
locally on the internet...
Try (they have manuals here... also)
Blue Rhino Outdoor Gas Heaters
Hope this helps
Carnac the Magnificent
Sep 19, 2017 | Patio Heaters
Garden Treasures 41000 BTU Stainless Steel Liquid Propane Patio Heater Logo
188 people viewed this question
Top Garden Treasures Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Lawrence Oravetz
Are you a Garden Treasures Patio Heater Expert? Answer questions, earn points and help others
