Question about LG LSC26905TT Side by Side Refrigerator
LG refrigerator GR-PI97NIS - replacing light bulb
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: the lever of my LG
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 05, 2011
How to replace lights on refrigerator LFC25760SB
In the LG bottom freezer refrigerator (model LFC25760SB), the light bulb covers inside the refrigerator and freezer compartments are attached using friction-fit clips.
It will be safest to unplug the unit, or shut off the circuit breaker. You may also need to remove Items, including the top 1 or 2 shelves.
Push the front of the cover gently toward the back of the refrigerator; LG's instructions show a screwdriver, but I would use something more flexible like an expired credit card or emty gift card. Swing the cover down to unhook the clips at the back.
Be careful with the bulbs, as they can get very hot, particularly if it takes some time to clear the way to the cover and get it off. I would close the door and wait a few minutes to let the bulbs cool off before removing them.
LG has a downloadable manual on their website that shows the procedure and gives the bulb specs (60 watt appliance type).
https://www.lg.com/us/lgecs.downloadFile.ldwf?DOC_ID=KROWM000110253&what=MANUAL&fromSystem=LG.COM&fileId=KROWM000110253.pdf&ORIGINAL_NAME_b1_a1=3828JD8991B%28ENG%29.pdf LG LFC25760SB Support Manuals Warranty More LG
Feb 28, 2018 | Refrigerators
LG REFRIGERATOR-FREEZER MODEL GR-B207WLQ HOW TO CHANGE LIGHT BULB IN REFRIGERATOR
Just remove the panel of the light bulb present in the
REFRIGERATOR and simply remove the bulb.
May 06, 2017 | LG Refrigerators
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Hi i have an LG GR-B206GVQA fridge freezer when we got up this morning it was not working at all i tried the fuse nothing wrong with that i tried the fuse on the control board on top of the unit that was...
Did you check the plug its self ? By plugging a lamp in the plug where the refrigerator is pluged into ? If the wall plug is good (could there have been bad weather) and then you plug fridg. back in and no positive results check to see if the inside light bulbs are good and work.
Aug 02, 2010 | LG LSC26905TT Side by Side Refrigerator
LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Apr 09, 2010 | Refrigerators
How do I open the plastic shield covering the appliance bulbs in my LG french door refrigerator to change the bulbs? I can't seem to open it without breaking the plastic. What's the secret?
Use a butter knife and insert it in the slot between the cover and white plastic holder and pull the knife lightly twords you.
Do this on both sides and the cover should come out.
Use 40W bulbs for replacement.
Jan 13, 2010 | LG LRFC25750 Refrigerator French Door
LG LSC26905TT Side by Side Refrigerator Logo
21 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
