Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Some times the picture gets a green and red hue and the menu turns from green to red ,
  • tugishlove May 21, 2009
    hi local wonder, thank you for your quick response, just a followup question: could it be environmental, the reason i am asking is that i noticed that it is happening when my new neighbors moved in and never happens when their out of the house? could it be a device or home appliance they're running?
  • Anonymous Mar 20, 2014
    Picture now has a reddish with overtone of greenish hue
  • 6,784 Answers
HI. this is being caused by a faulty convergence chip that is located on the convergence board. simply replacing this chip or replacing the entire board will fix this issue.
Posted on May 21, 2009
  • Michael Masters
    Michael Masters May 21, 2009
    If this happens in sequence when your neighbor is home, yes, this can be interference. it could be a high frequency radio or an magnetized object of some sort. there are many ways to interfere with LCD frequency and, if the neighbors are transmitting a high frequency micro wave or rf signal for some reason, it will interfere. i would still inspect the internal board for discolored chips
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Both the picture and sound work when the TV is turned on, yet the picture is distorted like a double picture and has a yellow hue to it.
Sounds like you have a convergence problem. If you go into the setup menu of your TV, there should be some settings to adjust the red, green and blue hues and re-position them so each color matches up. If this does not work or if you don't have a menu, your TV *might* have a circuit board with several plastic screws on it. These adjust the picture and it's a very tedious task to re-align each hue correctly.
My projection TV is an older model from 1995, which is probably why it has this circuit board in place of a convergence menu built into the TV.
If adjusting the convergence still doesn't work, you might need to purchase a new convergence chip.
May 20, 2011 | Sony KP-51WS520 51" Rear Projection...
Green hue
Unplug the TV from the wall and plug it back after 45-60s should fix the problem. However, it will come back from time to time so the same procedure will reset the video board. You'd want to upgrade the firmware on the ATSC tuner as well because old firmware was built before the final standard and when the TV goes digital in June 2009, it wreak havoc on all older HD TV. Go to hitachi website and download new FW for your TV. Copy the FW to an SD card and follow procedure from Hitachi to upgrade. It works wonder for my TV after the upgrade.
Sep 22, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
I am on MS paint and i want a copper color. What are the codes for getting that copper color? example Hue: Red: Sat: Green: Lum: Blue:
Check out this setting for Copper color in Paint :
Hue: 27 Sat: 127 Lum: 124
Let me know if this fullfil your requirement. Otherwise you can edit the color yourself by clicing on Colors Menu --> Edit Colors --> Define Customs Color --> Then move the cursor to select the Color.
You can add this color in the Color Pallete to get in work. Let me know if you face difficulty, I will assist you further .
Vote if you get the exact solution for which you are looking for.
Thanks Scott
Dec 07, 2008 | Microsoft Computers & Internet
Green hue on all inputs
Most likely there is a failure in the video processing. The flickering was from the failing components breaking down.
Your set can be serviced by an experienced tech who has spare boards and the facilities to service your set.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Phillips 51" Screen Distortion
See if the issue happens in the menu alsoif not replace the small signalbaord.
Apr 25, 2008 | Philips 51PW9303 51" Rear Projection...
GREEN AND RED HUE IN PICTURE WITH CABLE OR DVD
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Televison & Video
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
333 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
