Question about Samsung HLR5067WX 50" Rear Projection HDTV
HLR-5067WAX/XX Screen freezes and resets every few seconds
I just replaced the light engine as a whole in this set, now occasionally the set hangs on a signal. It freezes for a few seconds, the screen goes dark and then it resets and works for another few minutes before freezing and repeating. I have found that while the screen goes dark the bulb is still lit, also this happens on all inputs and even if the volume or menu is on a black or static screen. The static too looks odd. It has green and purple lines coursing through it instead of the normal salt and pepper. I have found that if I unplug the tv while it is still on and then plug it back in within a few seconds, the tv will then work flawlessly for a few days before going back to the resetting. During the working periods I can watch blurays, play xbox, high def or standard def.
I just recently hooked this up to cable and it does the same thing with the hdtv cable box. It hangs on the signal. Can anyone point me in the right direction? Is the DMD on the new light engine shot? Or is it something with the signal board. HELP!
  • Axle80
    Axle80 May 25, 2009
    Great! thanks for the wisdom. Give me a few days to do some diagnosing and I will post back shortly.
  • Axle80
    Axle80 May 28, 2009
    Thanks f
    President:
  • Samsung Master
  • 2,923 Answers
You have to check the 3 main boards inside your TV. Here are the boards that you need to check:
1. Analog board
2. Digital board
3. DMD board
A problem in the small signal stage will only be amplified in the final stage output so be sure where the problem originates. Here are the things that you need to do to check the DMD board:
* Access Factory Service Mode:
In Standby mode, press "Mute", "1", "8", "2" and "Power" to turn the screen on and enter service mode
Input screen will be whatever you have set as main input.
Check if there is an error in the DMD board:
Highlight the DDP1011, then TEST PATTERN
Press the right arrow key on remote to scan through the following screens:
Full Screen, WHITE, BLACK, RED, GREEN, BLUE, etc. until you get back to your initial input.
If the above screens do not appear, this is a DMD board error.
When the DMD board has been determined to be error free based on the test patterns check the DNIe:
Check if there is an error in the digital board before the DMD.
Highlight the DNIe, then TEST PATTERN
If the above screens do not appear, IT MAY BE from a DMD board, an ATI error or there is an Analog board malfunction.
If the DDP1011 and the DNIe passed, try to access a known working Analog board to complete my diagnosis for board change out then hopefully take this to component level repair.
It's also recommended to consult the manufacturer for second opinion.
Have a great day!
Posted on May 21, 2009
    Top Expert:
  • Samsung Master
  • 75,814 Answers
Do u need more assistance on this problem, sounds like the high voltage supply (flyback transformer) is shorted
Posted on May 26, 2009
My cg100 camera always freezes is this common.
Seems to be quite normal. The manual says on page 133:
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold the Power button for 6-8 seconds. The device reboots automatically.
If this does not solve the problem, perform a factory data reset. On the Applications screen, tap Settings > Backup and reset > Factory data reset > Reset device > Erase everything.
Jan 09, 2014 | Cameras
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
I can;t reset the change oil light on my dash of my 2007 lincoln town car I had the oil changed last week ?
This procedure work for one 2004... press mode button until oil life or change oil or change oil now is displayed press and hold mode button for 5 seconds until reset for new oil is displayed then hold reset for 2 seconds.
Additionally, I quite other comments about this subject....
Few issues have troubled technicians more than the infamous "Change oil soon light." We have even had quick lube shops send customers to me at the dealership to shut off this light.
Yes, the engineer that designed this system most certainly had flunked out of the "User Friendly" semester of college. The most common problem is between step 1 and 2 of the owner's manual. The natural tendency is that when we scroll through the menu to the "oil life XX%" mode, we lift our finger. This is where most go wrong. Once the "oil life XX%" comes up on the menu, do NOT lift from depressing the button- just hold for 5 seconds until the "Reset for new oil life" comes up. Again, do not lift your finger.
The parking assist is a different concern altogether. The parking assist light illuminated when it is deactivated- opposite of what seems logical. It was probably the same design engineer as the oil change system. If the system is disabled, (illuminated) it is intended to cycle back when the key is shut off.
Hope helps.
Jun 16, 2011 | Lincoln Town Car Cars & Trucks
H,i I tried to give a hard reset my phone but pressing the key recovery and has a symbol on the screen, now does not respond, how long should I wait or should it be immediately?
Did you press the MENU.
Follow the following steps:
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, andthen re-install it. After re-installing the battery, turn on the phone.
Mar 17, 2011 | HTC Hero Smartphone
When i turn it on it turnes off after a minute
Check the color wheel. If that is ok, replace lamp and ballast.
Dec 14, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
New nokia 6303 and it freezes
i have a nokia 6303c when i power on tis ok but after a few seconds the screen fades and becomes black then hangs and remains with lights on
Nov 10, 2009 | Nokia 6303 Cell Phone
IPhone touch screen freezes and stopped working
hold down the home and power button together, should reset the iPhone and stop this happening. (you will not lose any data)
Aug 04, 2009 | Apple iPhone Smartphone
My samsung hlr 5667 lost its colors. Only displaying red pixels in the dark areas of the screen... help!
How is the color of the tv menu. If menu also bad replace light engine. If menu ok replace digital main.
Apr 23, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Hanging
freezedMy HTC was working great!!...sudenly started to freeze and after that just turned off...I try to soft reset it....but it is still hanged how can i hard reset ?it worked at the begining(just for 2 seconds) but later the phone didnt start....and then it didnt continue the starting..sometimes after that just a clear white screen appeared. it freezed again.touch screen not working at all.
Sep 20, 2008 | HTC Touch P3450 Smartphone
Samsung HLR5067WX 50" Rear Projection HDTV Logo
147 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
