Question about Vizio Televison & Video
Using direct tv remote with vizio m321i tv - Vizio Televison & Video
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
SOURCE: VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Posted on Apr 11, 2009
  • 13 Answers
SOURCE: vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Posted on Apr 19, 2009
  • 100 Answers
SOURCE: what is 32inch vizio tv plasma code for direct tv
Try this, page 15:
http://www.directv.com/learn/pdf/System_Manuals/DIRECTV/DIRECTV_D10-300.pdf
Posted on Aug 25, 2009
SOURCE: Vizio 32 and Direct TV remote codes??
Oh Boy Good Day...code 10056 worked for me...FINALLY...have been searching codes for 17 months...cheers thanx ever so parseeker :))
Posted on Oct 18, 2009
What are the cisco cable box codes for vizio televisions
0281,0227,0294. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 05, 2014 | Vizio Brand Genuine smart TV remote XRT510...
42 inch vizio has picture (direct tv) but no sound. Tv is not on mute.
Did you check the RCA AV Cables? The ones with the red, white yellow?
What is the connection you have from Direct TV box to your TV. You might want to start on that.
It might probably as well related to any of the remote controls settings. Either of the Direct TV control or TV Control.
1. Check the cables
2. Check if there is any function on the Direct TV remote that will turn off the sound
3. CHeck the Vizio TV Menu Settings.
4. Try with other component such as DVD to discard the possibility of malfunctioning VIZIO Speakers.
Vizio offer a good customer service if still under warranty.
God Bless You!!
Feb 14, 2011 | Vizio VW37L 37 in. LCD HDTV
I want to configure my direct tv remote (hughes) to turn on my vizio tv. I can't find vizio as an option in the menu for set up. I also need a 3 digit code for vizio, however I only find 4 digit. how do i...
Actuly you can get the remote to work with your TV. I also have direct tv and a vizio and my direct tv remote works the tv. I need to get you remote model # to be able to help you program the remote. Once I have that I will give you the instructions on how to program it. Please add a commet when You can provide it to me.
Thank You
May 08, 2010 | Vizio VO47L 47 in. LCD TV
Apr 02, 2009 | Vizio L37 Television
Jan 15, 2008 | Vizio L32 32 in. LCD HDTV
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
18 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
