Question about Yahoo Mail
Viewing e-mail messages
I would like to have the messages cover more of the screen. Many messages have parts cut off on either the left or right side of the message. I have tried to use many screens such as view and zoom and it does not help. The help topics do not address this problem. Why is the screen for reading e-mail this way? It is not very user friendly. In some cases I have to go the website from the sender to read the entire message on a screen that is larger than the one I get when I open a message.
  • 903 Answers
yahoo are experiencing lots of problems at the moment, when I send emails to yahoo adresses I get them sent back almost immediatley.
Posted on Nov 26, 2008
SOURCE: trouble logginto yahoo mail uk.very urgent !
I had the same problem, but what I did was so helpful. I changed my mail to "Mail Classic" and I have no problem. I hope it works for you, too!!!!!!!!!!!!!!!!
Posted on Dec 04, 2008
  • 18 Answers
SOURCE: able to sign on and view mail under one screen
Try changing the screen resolution from 800 x 600 to 1024 x 768 on the one that doesn't work.
Posted on Dec 22, 2009
  • 18 Answers
SOURCE: i am unable to view my yahoo mail
If after signing in to Yahoo mail you get 'opening page about:blank' problem, this is not caused by a virus, trojan, or anything like that! Yahoo have been making changes to the appearance of their home page and also their e-mail. As a result, the screen resolution of 800 x 600 on many PCs will no-longer allow you to sign in. Try changing your screen resolution to 1024 x 768
Posted on Dec 23, 2009
  • 39 Answers
SOURCE: accidently resized my yahoo mail
try holding "ctrl" and "-"
or if your using firefox go to "zoom" "reset"
Posted on Mar 01, 2011
Thermal fuse part number
25851826-kucbmckx3u3x3wmaw0z02dzb-3-0.jpg Hello. The part numbers are as follows:
42 THERMISTOR 8577274
47 & 48 THERMAL CUT-OFF W/ THERMISTOR-HC STAT 280148(one part number for both thermals in a kit)
51 THERMAL FUSE 3390719
TIP--use a magnetic screwdriver that will take nut-driver bits
You will have to raise the top cover, then, on the right side corner, disconnect the door switch connector. Next, using a headlamp, look inside the unit, back towards the front near the upper left and right corners about 4 inches down on either side. Notice there is a screw on each side. Remove these 2 screws and that will release the front cover. Arc the top of it towards you and lift it off the metal positioning tabs at the bottom and set it aside. Remove the lint screen now. Remove the 3-4 screws that hold the lint duct assembly(metal blower cover) in place. CAREFULLY pull the cover away from the lint screen holder(be *darn* careful that you don't damage the wires connected to the moisture sensor bars on the upper right side of the lint screen holder). Now, carefully look for the thermal fuse attached to the blower housing. It will be the one towards the front, slightly to the left of the exhaust thermistor. It will have a pair of light blue wires attached to it. Note P9-1 BU(blue), thermal fuse, BU(blue). Replace the fuse and reassembly is the reverse--caution--don't forget to re-connect the door switch connector at the right corner--cause "It ain't gonna do a thing" (even if you pray for it to work! LOL)
25851826-kucbmckx3u3x3wmaw0z02dzb-3-1.jpg I hope this helps you!
Sep 05, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How do I receive G Mail messages on my laptop
Open Mail, on the left side of the menu bar click "Mail" then "Preferences" On that pop up screen, click on "Accounts"
On the bottom left side of the screen click the +
You can then check Google and put in your Gmail account information.
Dec 12, 2014 | Apple MacBook Pro Laptop Computer with...
Replace lcd on gateway NV57h77u
I disagree. The procedure is so easy no Service Manual is needed
1) Remove ALL power. Remove the AC adapter, and Battery.
2) Open the laptop.
The plastic frame in front of the LCD screen is the Display Bezel.
(Gateway? Believe they call it the LCD Panel Bezel)
Down in the BOTTOM corners, next to the Hinges, are screws to be removed. One in each bottom corner.
There are Screw Covers over these screws. The Screw Covers need to be removed.
Little round covers I believe to be made of plastic.
(Some models they are made of synthetic rubber)
I use a computer pick to Gently remove them.
Some use the tip of an X-Acto knife. I do not recommend this as there is a possibility of injury.
Perhaps a large darning needle. (Needle you sew with, but is Large in size)
Pick up at one edge of Screw Cover. Screw Covers are held on by a type of rubber cement.
I LIGHTLY stick them to the Display Bezel for safekeeping.
(Yes. They like to stick to the tool, your fingers, and it seems passing jets in the sky.
If you are careful with them, you should be able to reuse them.
If they do not stick anymore, use a toothpick, and apply a TINY dab of rubber cement to them/it )
Once the Screw Covers are removed use a No.1 Philips screwdriver, or equivalent Jewelers screwdriver; to remove the 2 screws.
The Display Bezel has TABS going around the exterior perimeter, of it's inside edges.
These Tabs snap into matching LATCHES on the Display Cover.
You can come from the Outside edge, where the Display Bezel meets the Display Cover, and use a thick guitar pick.
The guitar pick is wedged into the parting line, of where the Display Bezel meets the Display Cover.
Once a 'crack' is formed in-between the two, then the fingertips are used to gently start popping the bezel from the cover.
You slowly go along with your fingertips, and work along the top, then sides. By the time you have both sides almost loose, the Display Bezel usually pops off.
I like the flex method.
Come to the inside edge of the Display Bezel.
Where it meets the LCD screen. I suggest start on the Right side/Middle.
Use a fingertip, and lift up the inside edge of the Display Bezel up a little. Can't lift up at that spot? Move over. You are at a Tab/Latch.
With this spot lifted up a little, use the fingertip of the other hand, and slide under next to it.
Now use your fingertips as wedges, and pop the Display Bezel loose a little at a time.
I start at the Right side/Middle as stated. Left hand fingertips go DOWN the right side, Right hand fingertips go UP the right side.
Then I go across the Top, and down the Left side.
MOST of the time, as stated; the Display Bezel usually pops off when right side, and left side are most of the way popped loose.
NOT always though!
Sometimes you have to pop EACH and EVERY Tab/Latch loose.
Also; watch around the Hinge area/s.
Display Bezel can get hung up around them.
Go slow, and gently work the Display Bezel off, around the Hinge areas.
Display Bezel popped off, sit back; relax. You just did the hard part.
Wasn't so tough, huh?
This is what the Display Bezel looks like removed,
The MAIN view shown is a BACK view.
In the smaller views underneath, the 4th view from the Left, shows the FRONT view.
If you SET your mouse cursor in the middle of the Main view photo, the Zoom In feature is enabled.
You can CLICK on any of the smaller views, to make them appear as a Main view.
You can also see that the Hinge Covers, are an integral part of the Display Bezel. Shows you that when removing the Display Bezel, these Hinge Covers may need to be worked off of the Hinges.
Of course, may not; as I have previously stated.
The LCD screen is an Assembly. It is composed of layers.
These layers are kept in the factory set alignment, by a metal Screen Frame.
The Screen Frame resembles a picture frame.
There are THREE screws on each side of the Screen Frame.
These screws (Philips) go through metal Brackets, and hold the LCD screen/Screen Frame; to the Display Cover.
The Brackets are an integral part of the Hinges,
On EACH side, there is 1 screw towards the Top, 1 screw towards the Bottom/Middle, and 1 screw towards the Bottom.
Remove all 6 screws.
At the Top is the Webcam Cable. Unplug it from the Webcam Module.
(Cable pulls to LEFT side, facing laptop)
The TOP of the LCD screen is now tilted forward.
The Video Cable plugs into the Bottom side.
There should be a piece of clear Mylar tape, holding the Video Cable connector in place. Carefully peel it back, unplug the Video Cable from the LCD screen.
Remove the LCD screen.
Reverse steps to install new LCD screen.
For additional questions please post in a Comment.
Apr 12, 2013 | Gateway Nv57h77u Laptop/notebook
How do I change font size of my e-mails
Email Tool Bar
Spell Check - Text Size - Fonts - Colors
Emoticons - Bold - Underline - Etc
(These Options Can Not Be Saved As Defaults)
(They Must Be Set Up Every Time You Email Some One)
Set Up The Tool Bar
Settings For The All New Email
if the tool bar is not enabled click rich text beside the subject line
( When you start composing an email you can hold your mouse over the little icons you see above the message you are typing
they will tell you what they do )
spell check which is abc is above From above the message
for fonts use the first drop down box above your message to choose one
for text size use the second drop down box
Settings For Classic Email
click options on the right top side of the mail page
then general preferences
scroll down to composing e-mails section
check the box - compose messages as color and graphics
Text Size Adjustments For Any Webpage
go to top of this page in the grey area
click view
then text size
adjust size
Font Size And Screen Width For Your Yahoo Message"s
Steps For The All New Mail
click options on top right side of mail page
then mail options
then contact options
click mail on the left side
then font size
screen width can be changed there also
remember to click save
Steps For Classic Mail
general preferences
then font size
Oct 25, 2011 | Computers & Internet
My yahoo mail is working, i can recieve messages.. But I cannot see it as a whole on my screen. When I click on Inbox, the messages should appear on the right side right??.. But the only thing that i could...
Try to reset the Reading Pane. On the Yahoo Mail header (next to 'Delete', 'Reply', 'Forward', etc.) Click the arrow next to 'View' and fiddle with the settings in there - I think it is "Preview Pane" or "Reading Pane".
Mar 18, 2011 | Yahoo Mail
Can't view all e mail in full view
Switch the view of the yahoo mail.
First, take a look in the extreme top-left corner of your screen. The "Yahoo! Mail" icon is present. Glance to the right about one inch, and you will see your username. Below that are three links to click on: sign out, my account, mail classic. Click on the third link, mail classic, and it should take you back to yahoo's classic mail.
Hope this helps, if so do rate the solution
Jan 17, 2011 | Yahoo Mail
I use AOL. When you click on an email, a "quick read" on the side comes up then you have to double click the email again to actually open it wide. How do you turn off the quick read? I tried to find the...
well in aol, look on the email after it comes up, you will see if i remember a word "full view" that opens the mail in a window size pane but most of all it will keep that setting for your full session in aol mail. if your on there browser and mail is visable in quick view on top right,slide cursor over the icon (mail) then bottom left of that quick view screen click view all my mail. when it opens look for the full view setting you should be good to go
Sep 14, 2010 | Computers & Internet
Can not view my folder contents
try to upgrade IE to last IE8, and clean ie Temps
Jan 02, 2010 | Yahoo Mail
Microsoft outlook 2003 - no reading/viewing pane, whole right column (from, date,subj, size, file attach, tag, etc) is gone, so can't view the emails. only left column's Mail (favorite folder, all mail...
Click on the View menu, then
Reading Pane
and then choose from:
Oh No! you are not able to view the entire right column (from, date,subj, size, file attach, tag, etc. Hmm!
Current View, then
Customize Current View..., and then click
Reset Current View
Hopefully now you will be able to view the whole right column.
Jun 07, 2009 | Microsoft Outlook 2003 for PC
Yahoo Mail Logo
27 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
