Question about Electrolux WT30H240DU Dishwasher
C2 error code - Electrolux WT30H240DU Dishwasher
I am getting a C2 11 problem error on my Rheem tankless water heater, What that mean?
Just how much did you investigate this on the internet before asking here? I Googled " Rheem C2 tankless water heater" and found http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html. Look under Error Codes. Code 11 refer to gas supply/ignition. If you don't know much about tankles water heaters or gas ignition, call a Rheem Tech.
Dec 13, 2014 | Rheem Water Heaters
How do i cancell all codes in nokia c2-00?
sir my nokia c2-00 security code error bata raha hai please help me
Sep 10, 2013 | Nokia mobile C2-00 Dual SIMbiosis
Nokia c2 00 security cod
sir my nokia c2-00 security code error help me
Aug 21, 2013 | Nokia mobile C2-00 Dual SIMbiosis
How to fix c2 error code on 5400
1) For Rheem tankless water heater, C2 11 is usually means bad circuit board.
2) What is a 5400?
Is this a water heater?
What brand water heater. What type.
Is this gas or electric.
New installation, or older installation that started having problems.
Has required yearly maintenance been done?
Is the unit rated for correct altitude?
Has the water temperature been increased?
3) Add comment and include description of product, and best description of problem for possible assistance.
4) Call service technician.
Dec 30, 2012 | Water Heaters
Getting a error code C2 82 on PTG-42PVN / RTG2-42PVN Natural gas indoor
This error code will occur for two reasons:
1. The heater has lost its programming and you will need a new programming chip from Rheem. (866) 720-2076
2. The igniter module is located behind the Printed Circuit board and will need to be relocated.
Apr 10, 2012 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
I forgot my nokia c2-00 security code
sir my phone nokia c2-00 security code error bata raha hai please
Dec 21, 2011 | Nokia mobile C2-00 Dual SIMbiosis
Restriction code for nokia c201
I HAVE A NOKIA C2-01 MOBILE FROM ENGLAND WHEN I INSERTED SIM IT ASKED FOR THE RESTRICTION CODE .MY IMEI CODE IS 358607043358936.PLEASE HELP...
Sep 18, 2011 | Cell Phones
Norcold fridge displaying error code c2
My refer was displaying error code C2...I troubleshot it and found that C2= "no 120 VAC" coming off the board for heaters. Heaters were good (checked out with Ohm meter) so it had to be on the board. Turned out to be easy...about only parts on the board that could cause this problem was a S.P.S.T. relay...purchased from Digi-key for $1.70...beats the price of a new board nearly $500. Been working fine now for about 2 weeks.
Aug 23, 2008 | Refrigerators
Electrolux WT-4 -- C2 error code -- What is it?
C2 is Boiler temp too high.
Possible causes include:
Boiler Temp setpoint adjusted above 90C in programming
Boiler relay welded/melted
Boiler water level sensor not functioning correctly
Hope this helps,
Kermit
Aug 20, 2008 | Electrolux Dishwashers
Electrolux WT30H240DU Dishwasher Logo
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
