Question about Refrigerators
Kelvinator fridge C2408 water at bottom of fridge and without changing temp. back panel starts freezing
Water runs to the bottom of the fridge and without changing the temp. setting the back panel on top back of fridge starts freezing. How can I fix this?
meBNme
  • 334 Answers
SOURCE: fridge too cold
The temp sensor or the thermostat is bad.
It is reccomended that the sensor be replaced whenever a T-stat is replaced.
You can purchace both for less than 50 bucks with most models at your local appliance parts warehouse.
(The T-stat is the part that you turn up or down to adjust temp and the sensor is the wire coming off of it to a remote location in the fridge. With some models it is all one part, with others the sensor can be removed seperatly.)
Posted on Dec 30, 2008
Maytag317
  • 1136 Answers
SOURCE: Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
Posted on May 10, 2009
alex_salve
  • 78 Answers
SOURCE: fridge area is freezing
unplug the refrigerator for atleast 6 hrs , again connect it , should work
Posted on May 17, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
  • 308 Answers
SOURCE: bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Posted on Nov 16, 2009
Testimonial: "EXCELLENT!!!!!!!!!!!!!!"
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
N325T water collecting at bottom and back internal wall freezing up
That sounds quite normal as the rear panel is the evaporator skin. Check the drain hole at the bottom isn't blocked
Apr 22, 2012 | Refrigerators
My kelvinator refrigerator doesnt produce ice in the freezer,,machine still working but not getting warmer the back of ref
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 20, 2011 | Kelvinator Refrigerators
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My kelvinator 290 refrigerator (not fridge/freezer) leaks water which apears underneath the 2 crisper drawers at the bottom? How do I stop this from happening. Can I unblock something?
you need to defrost the fridge. you most likely have a build up of ice in the collector from running the fridge to cold.
once down plug back in freezer and run on low temp for 24 hours and increase in small increments until the fridge is to a good temperature (about 39 degrees F)
Jul 02, 2011 | Refrigerators
Freezer temp is -4 and refrig is 38. Not sure if these are correct settings but water in freig bladder keeps freezing and can't get water. Warmed bladder twice to get water to come out. If freezer temp...
Sorry if you don't like this solution, it does not make it work correctly. But my water works all the time now.
We too had the water dispensor stopping due to freezing of water in the storage tank. A blow dryer and about 10 minutes later we could get it working again.
We tried different fridge temp settings , and according to a thermometer placed inside the fridge in various locations we are getting the fridge temps we want, so it is not runing too cold.
I tried insulating the storage tank and the lines, this did not work.
I removed the tank and just connected the two lines, this still did not work.
I finally just pulled the lines out of the fridge completely and connected them underneath the fridge so water runs from the valve at back straight to door. The plastic panel on bottom was a great place to store the lines. I drilled a hole to reroute the door line to this area . Line runs behind lower plastic cover on front . The water does not get cold, but it never stops flowing, this was more important to us. I did consider rerouting both lines to the top shelf and putting the storage tank back in to get colder water, but no one minds the way it works so I probably will not do this. I would have run them up the back to avoid the inside lower area of the fridge. In the long run I will avoid this brand and avoid "twin-cooling" completely. All my neighbors and friends who bought this type all had to throw them away as they were too dofficult and expensive to keep running.
Jan 15, 2011 | Samsung RS2534 Side by Side Refrigerator
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Water reservoir in bottom back of frig keeps freezing up.
Too cold in fridge if it is freezing is your milk or other items freezing. Check temp in fridge with a good thermometer.
Nov 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge area is freezing
May 17, 2009 | Refrigerators
'ice dam' on bottom of freezer, now problems with fluctuating temps
Kat, you only have 1 problem happening.And no this is not due to the original repair. (though I have to admit... replacing the filter/drier, starter and compressor is NOT part of routine maintenance and has me a little befuddled.) Your evaporator drain is plugged. Most likely with what we in the biz call "bio-gookus". This is normal, but must be cleared to keep the water from puddling and coming out your freezer door. With the evap panel removed and the drain hole exposed, pour 1/4 cup of HOT water into the drain hole. Use a small screwdriver or other small instrument to pick out the ice buildup. Once this is clear, use something like this http://www.azpartsmaster.com/shopazp/Gallo+Condensate+Blowout+Guns+(A66800).html to blow out the rest of the lines. After doing this, pour more hot water into the drain to verify free flow. This will take care of your leak problem. Now... the frost buildup. NEVER RUN YOUR FRIDGE WITH THE PANELS OFF! They are there for a reason, believe it or not. They direct air flow across the coils (both evaporative and condensing). Frost buildup is normal, though you may be experiencing higher levels of frost because of the panel missing...Your fridge utilizes an automatic defrost system. It'll initiate every 8 hours. This is controlled by a timer located in your fresh food section. The defrost heater RARELY fails on these. Fix the evaporator drain and replace all panels. This will solve your dilemma.
Aug 09, 2007 | Maytag MSD2758G Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
