Question about Garden
Briggs free repair manual
Sitting gov idle speed
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Could you tell me where I could look for a free
This may be of some help to you.
http://engines.myfaqcenter.com/Answer.aspx?p_faqid=3353&selectCats=Troubleshooting - Repairs
Posted on Jun 13, 2010
NEED REPAIR MANNUAL FOR BRIGGS AND STRATTON REPAIR MANNUAL
Hi - you can download manuals for all current and the vast majority of older engines direct from the Briggs website (owner/maintenance manuals and Illustrated Parts Lists) . You can also buy proper 'strip down and repair' manuals from Amazon among other places. Note - these are official publications and it's unlikely you will find them for free (they're illegal if you do!).
Aug 06, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
Apr 26, 2012 | Briggs & Stratton Garden
Do they all 5 hp briggs boat moters jump around when they shift or is there somthing I am doing wrong thank you
Your idle speed is to high. These have (most of them) a wire wound round a drum for the clutch (called a bendix clutch) and it is very positive. so your idle must be real slow not to damage. it. If the engine will not run slow it's most likely problem is mixture adjustment after that would be the bottom seal.
Aug 16, 2011 | Briggs & Stratton 5 Hp Outboard Service...
I need a free copy (download) of a workshop manual to suit a Briggs and Stratten 375 petrol engine?
Workshop (repair) manuals are available for ALL of the Briggs and Stratton engines. They usually cost money though. The free downloads are only for the owner's manuals. You can do a search for Briggs engine repair manuals. There are many, many of them available.
May 22, 2011 | Garden
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Aug 20, 2009 | Briggs & Stratton Garden
Mcculloch chainsaw 2416
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
Aug 03, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
2,392 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
