Question about Samsung HL-R5656W 56" DLP HDTV
LOUD BUZZING SOUND WEN FIRST TURN ON
FIRST TURN ON TV MAKES LOUD BUZZING NOISE AND LAST FOR A FEW MIN. EVEN WHEN PICTURE COMES ON.THEN IT STOPS AND HAPPEN AGAIN NEXT DAY WHEN TURN ON .PICTURE GOOD AND SOUND IS GOOD
  • 1694 Answers
SOURCE: No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Posted on Oct 19, 2007
SOURCE: loud buzzing noise
Loud buzzing sound usually mean the color wheel need replacing. Color wheel runs at high RPM and if it is out of balance it creates that buzzing sound. A glass on the color wheel is most likely shattered. Let me know if helpful.
Posted on Aug 18, 2008
  • 49 Answers
SOURCE: Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Posted on Jan 24, 2009
SOURCE: TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Posted on Apr 10, 2009
rustym62
  • 201 Answers
SOURCE: poor picture quality and loud buzzing noise
Sounds like your color wheel is failing they make a loud sqeauling noise when they begin to fail.Run you somewhere around $300-400 to have a tech repair it.
http://the-tv-dude.blogspot.com
Posted on May 04, 2009
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Buzzing sound on TV, Bad Picture...
You have a Genesis 1. Make sure that you are using the correct power supply; the first models use a different voltage than the second or third models.
Sep 30, 2009 | Sega Genesis Console
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Nov 21, 2008 | Televison & Video
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Samsung HL-R5656W 56" DLP HDTV Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
