Question about Garden
Twist n edge te475y - Garden
2 Suggested Answers
SOURCE: i need a manual for weed eater max te475y twist n
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/te475y.html
I ran across your question when I to was looking for the manual. This is what I found it seems like the right one I will find out when I start working on the thing good luck!
Danielle
Posted on Oct 02, 2010
My weedeater max te475y starts on full choke but wont run on half or run please help
problem--- main jet blocked or diaphragm has failed
check prices of parts as a new carby is around the same price on e-bay
Jul 16, 2016 | Garden
How to fix my Weed Eater MAX TE475Y TWIST 'NEDGE that wont start
First diagnose whether its a fuel, ignition, or compression problem. Remove the air filter cover and air filter. Spray a shot of carb cleaner into the carb and attempt to start ( choke should be open, throttle closed). If the unit starts on the prime then you have a fuel problem. Proceed by rebuilding the carb and if the fuel lines or primer bulb are brittle or discolored then replace them as well. Be sure that you use fresh fuel ( less than 2 weeks old) and if ethanol is in your fuel be sure there is no water in your fuel. If the unit doesn't start on the prime then check spark and compression. Compression should be between 120 and 140. If less than 90 the unit should be replaced.
Aug 24, 2014 | Garden
How do i repair a choke lever in a weedeater te475y gas trimmer? Does the lever pull straight out of the carburetor.
Upon inspection of this model machine, it appears that the choke lever shaft is pressed into place when the carb is manufactured. Removal may be possible, but probably more damage will occur. I have this same model machine with a Zama carb having flooding issues after soaking in a bath-type solvent overnight. This is NOT recommmended.
Here is a parts breakdown for your machine:
http://www.ereplacementparts.com/weed-eater-te475y-gas-trimmer-parts-c-17589_17626_18141.html
Unfortunately, there is no avaiilable release date for the part you need in question....On the page I made available it is part # A800 or A801...depending whether you have the Walbro or Zama carb. Mine has the Zama.
Jul 09, 2010 | Husqvarna Garden
I need a manual for weed eater max te475y twist n edge
Danielle
Jun 15, 2010 | Garden
I bought my TE475Y and last year and need to put new string on and cannot find manual. How is it secured? Thanks
This is most likely just put through a hole and tied off on the flywheel. Take it apart first. Then see how it is secured.
Aug 23, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan TE475Y motor upside down
No not that I have heard of
Sounds like assembled wrong to me
if you haven't already done so there should be 2 or 4 allen head screws on the housing squeezing pressure on the shaft you be able to loosen these screws and turn the shaft tube into the correct position and then retighten the allen head screws
Aug 04, 2009 | Poulan Garden
they were designed that way so the fuel will not spill on a hot engine and cause a fire.
Aug 04, 2009 | Poulan 17" T&E Gas Trimmer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
