Question about Kenmore Elite Oasis 27052 Top Load Washer
Replace coupler on kenmore top loader would like diagram
    Problem Solver:
  • 3 Answers
Go to searspartsdirect.com. You will have to put in the model number to do a search. The search will produce an exploded view along with the parts list and prices. If you're wanting to replace the coupling; the easiest approach is to lay the washer face down. Remove the motor mounts and replace the coupling. The couplings are plastic and fit tightly to both shafts. Pry coupling loose from motor and washer with a screwdriver. Install one of the coupling halves on each shaft. Sit the rubber center section on to the motor half of the coupling and install motor and motor mounts.
Posted on May 21, 2009
My kenmore washer don't spin
Probably need more information but guessing its a top loader and the motor is turning but the drum is not spinning but the water is being emptied? If that is the case it is probably a worn out coupling that needs replaced. The pump shaft runs through the gear of the pump body and also through a coupler. The coupler will eventually wear to the point the motor shaft just spins inside the coupler. If it is a front loader there is probably a V belt that is broken or damaged.
Oct 05, 2015 | Kenmore Washing Machines
Can the motor sensor,motor and bearings be replaced at what coast?
Of course the motor can be replaced. I don't think you have a motor sensor on a top loader. What bearings are you talking about? Normally the motor coupler wears out many times before the motor goes bad. The coupler connects the motor to the transmission. Go to www.sears.com/parts and put your model in and you'll see all your parts.
Aug 28, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Believe that my problem can be fixed with a belt replacement but cannot figure out how to get washing machine apart in order to replace. Kenmore 22442 top loader.
this video shows step by step how to replace the MOTOR COUPLER which the manufacture of that washer has used instead of a belt for about 15 years now
http://www.youtube.com/watch?v=9K1KHEogf3c
Part number for that coupler as shown in the video is 285753A
Aug 26, 2011 | Kenmore 22442 Top Load Washer
My kenmore 90 series top loader washing machine will not spin,but does drain and make a sound
If this is a Kenmore top loader such as the one you posted this question under, it sounds like you have a broken motor coupling. Failure to agitate or spin accompanied by the sound of the motor running with no tub action are some of the symptoms you can experience with this problem. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If you determine the coupler to be defective, the next link explains how to access the coupler and replace it:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is usually sold as part of their in-store inventory. The average cost of a motor coupling is about $15.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Kenmore washers are manufactured by Whirlpool, so these instructions do apply. If any of the links do not work for you, copy and paste them to your web browser.
Apr 27, 2010 | Washing Machines
Couplin for kenmore washer
If you're referring to the motor coupling on a Kenmore top loader, the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
If you've already determined the coupler to be defective, the next link explains how to access the coupler and replace it:
The part number is included in the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is commonly sold as part of their in-store inventory.
If you have any questions, please post back with your complete model number (located on a nameplate along the wash tub rim under the lid) so I can provide you with better assistance. I hope this helps you.
Feb 18, 2010 | Kenmore 24032\24036 Top Load Washer
The drum is not spinning. I hear a noise like when you stick something in your bike spokes.
Assuming that this is a Kenmore / Whirlpool top loader with a direct drive system, the first thing to check is the motor coupling.
The transmission and motor have plastic parts that connect through a rubber coupling.
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:661560Substitution:285753A $18.50 If the coupler rubber piece wears out, the pins on the motor and transmission sides will rub together making the sound.
If the coupler looks good the problem is likely in the transmission.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Top load direct drive will not spinn, but pump
oasis checks are complex if this is what it is, most likely you will have an error code, what is it? If its not an oasis, but a reg top loader, replace the motor/transmission isolation coupler.
Jun 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite top loader washing machine is not spinning well
USUALLY ITS A BROKEN COUPLER TOP 15 YRS AND NEWER DO NOT HAVE BELTS
Nov 29, 2008 | Kenmore 24032\24036 Top Load Washer
Older Style Top Loader Washing Machines
if the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
Aug 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
674 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
