This is regarding Trident Exel 549 RMN Gasfire which has been working nicely but now main flame is not working. pilot flame is working. there is no click sound and no green led light. What should i do
Where do I get manual/troubleshooting
t1m130
  • 86 Answers
SOURCE: pilot flame lights but goes out when knob is released
i would try cleaning or replacing the thermocoulpe if you did replace it make sure the flame is touching the thermocouple
Posted on Jul 30, 2009
  • 77 Answers
SOURCE: dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Posted on Jan 22, 2010
liteswink
  • 99 Answers
SOURCE: White Rodgers main gas valve operation.
pleas follow the troubleshooting page 9, 10 and 11
Posted on Jul 07, 2010
mxc2
  • 146 Answers
SOURCE: Pro-Com Gas Heater Some times the pilot light goes
Many times the thermocouple will build up so corrosion where it seats into the gas valve. This will cause the heater to just go out at random time. When the pilot goes out it will turn the gas valve off so no gas will escape from the valve.
Try cleaning the end of the thermocouple and see it that takes care of your problem.
Posted on Oct 01, 2010
  • 2597 Answers
SOURCE: pilot light wont stay on. How do you adjust pilot
then the pilot is blocked needs cleaning out or try blowing it out with air , or undone pilot and remove pilot injector and clean it .
Posted on Nov 02, 2010
Testimonial: "You were right. I blew out the pilot orifice and stove is working well. thanks"
Position of coals in trident exel
Request a manual from Trident.
Nov 05, 2014 | Heating & Cooling
Lennox G20 gas valve switches off then on Intermittently?
This could be a dirty flane sencor of the pressure switch check hoses are tight and not spilt , try jumping out the pressure switch see if that makes it work also check air fliter is clean .
Feb 11, 2013 | Heating & Cooling
At 300F after half hour, pilot and main gas burner was going off. When re-lit would stay on only 5 minutes thereafter. Had the thermopile changed(bought locally- not original from Imperial but identical),...
Hi there.
The thermostat will only shut down burner flame but not pilot flame.
Try tightening all wiring connections.
By using an ohm meter, check the continuity across the hi limit terminals when the pilot goes off, your hi limit may be tripping prematurely causing pilot flame to shut down.
Regards.
Jul 29, 2011 | Kitchen Appliances - Others
Hi there We have a Trident Excel 549 RMN fire which was already installed when we moved in. British Gas will not service the fire as we do not have the manual. I would be gateful if you knew how we...
terry, I have to agree with you. There's very little out there concerning your model Trident Fire. However, I did locate a company by the name of Trident Systems Fireplaces in the UK. Here is their website link below and their contact information. Hopefully, they can help you.
http://www.trident-systems.co.uk/index.html
Apr 13, 2011 | Heating & Cooling
Trident system excel plus gas fire problem, fire wont light on main flame pilot light is on and is a good flame checked injecter all fine,fan runs but the green led light 4 the fan isnt on? any help would...
Hi, fault is out in the fan box when the green light does not come on ,could be pressure switch or electronics.I have spares or can repair depending on where you live.
Jan 05, 2011 | Televison & Video
Make = Trident exel natural flame gas fire - model fan powered rear flue - 549 RMN FEF +3 The fire ignites and runs normally for about 10 minutes and then the gas side completely cuts out (both the...
Hi this is a oxy pilot problem as you say, would be best to replace. There are two types that were used on Trident /FEF fires,Ican help with either but need to know which one ,get back to me for further help .Will.
Nov 11, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
GE GAS RANGE OVEN PROBLEM
two options.first does the pilot flame look good (a nice blue flame)?if so you will see a metal probe next to the pilot,use some sandpaper and clean that probe up.if that solves your problem so be it.second if the first thing doesnt work its probably the ignitor board not sensing the flame.the way to definitly tell the one or the other use a small torch and heat up the probe like i said and turn the oven on.if the main burner comes on then you know its the probe which is called a thermocouple and is cheap.hope this helps.
Aug 08, 2007 | GE JGBC20 Gas Kitchen Range
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
