Question about Refrigerators
Ge gss25lgpa Fan is not working and freezer is warm. I need to locate the fan and how to get to it.
  • 1462 Answers
SOURCE: Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Posted on Apr 24, 2007
  • 263 Answers
SOURCE: ge gss22jfmcww side by side refrigerator warm
yeah if the fan does not work when you press the light switch thats the cause for the temperature proble, because the low temperature is not circulating stays just in one palce and yes you can replace just the fan get the manual from GE to see how to do it
Posted on Dec 30, 2007
  • 1314 Answers
SOURCE: GE side by side refrigerator gss22jfmcww not cooling
they are talking about the motherboard at the back of the unit and are prob right parts people see the promb a lot and was just trying to save you some cash good parts store pull the fridge out you will see a panel at the back on the freezer side pull the cover and inspect and you will see a board look for a burned resistor ge has corrected the problem and the new board cures the problem just follow the inst instructions
Posted on Jan 01, 2008
SOURCE: GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Posted on Aug 14, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
Where are the coils on a GE model GSS25LGPA CC fridge ... Are they under the fridge or in the back?
if u simply look at the unit u can tell either its a condenser fan cooled or evaporator coil cooled the back will have a wired coil like cage or at the bottom it will have a fan condenseor unit see pics attched
Apr 24, 2015 | GE Refrigerators
Fan stops working
I HAVE A 13YR OLD GE FRIDGE, THE FREEZER IS WORKING BUT THE FRIDGE IS STAYING WARM AT 50 degrees, I do not hear my defrost fan running in my freezer how can I replace it if this is my problem?
Jul 07, 2012 | Refrigerators
Fa n doesnt work in freezer .fridge is warm .freezer wont freeze properly.
Sounds like the evap fan needs replacing. (Unless you have a GE fridge, on GE fridge replace the main control board located behind the refrigerator.)
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie GOFAR Services, LLC
Aug 26, 2011 | Whirlpool Refrigerators
FREEZER COLD REFRIGERATOR WARM EVEN AFTER TEMPERATURE ADJUSMENTS WERE DONE.
Check to see if the freezer fan is turning. If this fan doesn't work properly, adequate cold air is not moved from the freezer to the refrigerator.
If the fan is turning, you likely can hear it. It should be behind an access plate at the top of the freezer. If you can't hear the fan, remove this plate, and look at it. If it's not turning, you need to replace the fan motor.
Oct 14, 2009 | GE PFS22SISSS Stainless Steel French Door...
Freezer works, but fridge is warm. Water had been draining from freezer into fridge, and freezing up in the bottom of fridge prior to this.
Sounds as if your evaporator fan located in the fridge part of the appliance is out. This fan is usually located by the temp control switch. If you open the fridge and listen you should hear the fan humming , if not, then replace the fan. Take the model and serial number to an appliance store and they should be able to get you the part. Good luck on your repairs.
Dave
Sep 30, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Ge profile evaporation fan installation. Where is it located?
It's located in the freezer compartment . May have to remove all panels , including the icemaker , to install it . If the fan isn't working though , the problem is probably the main control board , located behind an 8 " X 10" panel , on the back of the refrig . Usually , a resistor burns out and the freezer fan stops working .
Sep 19, 2009 | GE Refrigerators
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
Oct 13, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ge gss22jfmcww side by side refrigerator warm
Dec 30, 2007 | Refrigerators
Refrigerators Logo
11 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
