Question about LG 65LW6500 65 inch Class 3D LED LCD TV, FuHD 1080p - Bund- with BD650 3D BRay Player with SmartTV, FuHD 1080p Resolution, USB 2.0, Dolby TrueHD, Wi-Fi Ready
Deleting channels can't delete channels which are not required
Restore deleted channels tv
Repeat the initial setup routine to search for and store active channels. With the change to digital, channels are added and deleted all the time
Jun 02, 2013 | Televison & Video
I want to delete channels on alba tv
press the menu then go to programming channel, select channel you want to delete.
Nov 25, 2012 | Televison & Video
How do I delete channels not wanted and get channels I have lost the past couple of days?
just press the menu either in the remote controller or in the tv panel. and then go to channel set up this time you can delete channel and can add channel you want and then save in the memory.
Sep 07, 2012 | Insignia Televison & Video
How to delete channels off a 32
Most but not all sets have in the menu where channels are programmed a feature to add or delete channels from the up down memory--this is done with the original remote--universal usually will not be able to do it.
Look for channel setup and then add/delete feature.
Apr 30, 2012 | Emerson Televison & Video
My girlfriend has a toshiba 32rv530u TV. when she first connected it to her time warner cable everything worked fine. since then time warner has added free hd channels for the local commercial stations...
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Feb 06, 2011 | Toshiba REGZA 32RV530U LCD TV
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
Jan 19, 2009 | Emerson EWF2004 20" TV
How to delete unwanted channels off freeview
go onto the menu and enter the pin.then go to child lock and
select the channels you dont want your kids to watch so when they go to the bad channels they will have to enter the pin whitch they will not know.
Jul 29, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
How do I delete a channel?
The easy way for most of the TV's to delete a channel is to go into Menu on your remote and go to Add/Delete channels. Once you are in this screen you should have an option to delete a channel. Press that and type the channel number to be deleted. It should work. Good luck.
Jun 09, 2007 | Durabrand DU1301 TV
Deleting a channel
Orion builds that unit and I can not find an owners manual online for it anywhere. If you want, you can buy on here: http://www.orionsalesinc.com/miva/merchant.mvc?Screen=CTGY&Store_Code=OSI&Category_Code=DU1301 It should tell you in there how to go about deleting and adding channels.
LG 65LW6500 65 inch Class 3D LED LCD TV, FuHD 1080p - Bund- with BD650 3D BRay Player with SmartTV, FuHD 1080p Resolution, USB 2.0, Dolby TrueHD, Wi-Fi Ready Logo
44 people viewed this question
Computer Repairing
Computer Repairing
