Question about Honeywell Programmable Thermostat Heater
Just hooked up Model HWF!GB-15-240 power to the unit but wil not turn on.
Power to the thermosat but system will not turn on. warmly yours floor heat. All connections are correct 240v L1 & L2 Stat will not light up
2 Suggested Answers
  • 3368 Answers
SOURCE: Have a ct87k. Got power at wall. Plug t-stat nothing.switches are both off for gas.
Those normally do not fail, they have a mercury switch in them. However there is a cravat they have to be mounted level and up side up. If that is the way it is mounted then just replace it.
Posted on Dec 19, 2014
What is Radiant Floor Heating System anyone can tell me?
I think the concept behind the Radiant Floor Heating System is that Installed tubes or heating element, which contains water beneath the floor, which warm our floor. For more information about Radiant Floor system you can check this site.http://www.ps2i.biz/
May 28, 2013 | Mountain Plumbing Plumbing
Out thermosat for our furnace and air conditioners will not work. There is no poweer going tot he thermostat at all.
Hi, if you have no power to the stat, go to the furnace if this is a split system. Depending on the year you have, this unit may have the main circuit board with a 3 to 5 amp control fuse plugged into it. If this is what you have, check this fuse, it is the same as the fuses in your car. If you don't have this circuit board, locate the transformer where your thermostat wires come in and check for power at both the 120 volt primary side ( power in ) and see if you have 24 volts coming out of the secondary side of it. If no power in, check the circuit breaker to the furnace. If there is power in and nothing out, the transformer is gone. Check close for any breaks in the stat wires at the furnace also. I may need to have the model and serial numbers, and if its a split gas fired or a heat-pump unit if this information does not apply to your unit. Let me know.
Shastalaker7
A/C, & Heating Contractor.
Mar 11, 2011 | Coleman Heating & Cooling
Hitachi model No 32LD6600B turned telly off at plug last night last night now will not come on no standby light if you heat power board it will come on and stop on until turn of at plug again Thanks
1. YOUR flyback is going bad 2. Peform a removal and replacement 3. check your error codes first to ensue nothing else exists 4. Proceed to change out the required parts 5. Observe all electrical risks 6. Order replacements from jimmyparts.com 7. Ensure to always remove power 8. Ensure to always use electrostatic wrist strap
Generally what occurs is the units soldered connections on the main projection board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
Jan 29, 2011 | Hitachi Televison & Video
After i had the the gas turned on at the house i tried to start the furnance i turned on the gas then turned on the power switch set the thermosat and the blower fan started and stopped but the heat or...
If the gas has been off for a long time there may be air in the system preventing furnace from firing. Try to reset unit by turn power off and then on a few times and see if it clears out.
Dec 17, 2010 | Heating & Cooling
Central heat does not blow hot air, just warm air weakly
Sounds like some of the elements are not working. You being in Florida they may not have put very many elements in. It was 61 degrees last week. I know because I'm a Dolphin Fan. You will need a current sensing meter to check the elements.
Jan 04, 2010 | Heating & Cooling
Cold shower
You posted to the category:
Tritton Technology | T-NAS 120GB (trinas120) 120 GB Network Storage
Take the defective unit to a qualified repair-site, for trouble-shooting.
Nov 14, 2009 | Tritton Technology T-NAS 120GB (trinas120)...
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Main oven of cooker is on, fan is working, but not heating up. The top oven/grill is working.
Most likely a bad,open, heating element. Turn off power at breaker, remove element ohm with ohmmeter if good. its the thermostat or control. However, some units have resettable thermosats
Mar 11, 2009 | Ovens
Using fan relay to ad a/c to mobile home
Remember a fan switch has 2- contacts pus coil power (24volts) a normaly open --and a normaly close thus n. o. contacts and a n. c. .. contacts and and you hook the 24volt coil contact to cool and the hi-speed fan switch to the n.o. contacts... SO when it don't calls for cool the n.c. contact wil send power to the low speed wire for heat (red to the fan motor which connects to the temperature control which cycle on the fan when calling for heat! HEY, you didn't give enough information, like WHAT___WHERE___WHEN__WHO ??? ____ model #-- name of unit-- age-- gas fire or electric ---upflw or downflow?
Sep 09, 2008 | Heating & Cooling
Unit will not turn on
I realized your problem. i think the problem is the main board of your unit. pls spicify the model and brnd.
Nov 16, 2007 | E-Machines Emachine T5026 power supply **...
Heating & Cooling Logo
35 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
