Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Lg refrigerator lsc26905tt control panel not working
Control panel lights frozen. Fridge and freezer are not cooling. Unplugged it and plugged it back in and problem stopped for a few hours, then happened again.
  • 116 Answers
SOURCE: control panel for freezer and refrigerator
Behind the back panel of the freezer section is the evaperator assembly. on the rh side of the evaperator is a sensor pack that is for the defrost cycle. there is a thermo fuse inside of this pack that is open. The fridge goes into an error state if this fuse is open. unplugging the fridge resets the system. the sensor pack will have to be replaced.
Posted on Apr 27, 2007
  • 489 Answers
SOURCE: I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
Posted on May 11, 2008
22yooper
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
SOURCE: control panel shows "Er dH"
The “er dh” code means a problem with the defrost cycle. It is triggered when the defrost sensor does not reach 46 degrees F within 2 hours of the defrost cycle starting. If indeed the defroster is not working, the evaporator (in the bottom of the fridge in the freezer compartment and behind a plastic cover) will eventually ice up completely, blocking the flow of cold air to the upper compartment. Use a thermometer to check the upper compartment to verify that no or little cool air is reaching it.  If the evaporator is iced up, the defrost cycle is not working. Quick fix to restore operation to the upper compartment: tape over all vent holes in the upper section to keep that cool while you work below. There are about 6-7 vent opens in the back wall and two large one on the floor of upper compartment. Remove freezer door, drawers, slide rails and pull back the plastic cover (2 screws hold it in place, one in the center and one behind the ice maker) at the rear of the freezer section to expose the evaporator. Spray hot water on the ice accumulation on the evaporator (it looks like a radiator) to melt it (remembering to sop up what flows to the drain pan at the rear). The entire operation can be done in about 30 minutes (most time is used for removing ice and sopping up water from the drain pan). All should be ok for 3-4 days depending on humidity before the evaporator ices up again.  In the meantime, order a replacement control board. You can view this by removing a panel w/ 3 screws at the rear left of the refrigerator. This panel controls all refrigerator functions, including defrost. Most likely, the integrated relay for the defrost cycle failed. Swapping out panels is a 10 minute job. Panels cost about $116 incl shipping from repairclinc.com. Shipping is about a week.  You can find a free service manual on line that will help to identify all parts and is particularly useful for removing doors and trays so you can get at the evaporator.  All in all, the customer service is useless. The fridge however is very easy to work on and amazingly simple. The replacement board has a slightly different relay for the defrost heater, so LG may have realized a problem existed with the original. It is also possible that electrical surges damaged the relay.  In any case, 10 minutes and $116 seems pretty minor to have the fridge back to new condition. Good luck.
Posted on Apr 16, 2009
  • 118 Answers
SOURCE: LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Posted on Oct 26, 2009
LG LSC26905TT refrigerator not freezing. Everything is melting in the freezer and fridge.. Lights are on, but no cold air is coming.
Remove all items from the fridge and keep open the fridge doors for atleast 2 days and that will remove all the frosted ice on the evaporator(which can't be seen) and shall work fine after two days.
Feb 26, 2014 | LG LSC26905TT Side by Side Refrigerator
LG LFX25950SW refridgerator?freezer not cooling down
Click this link http://c.searspartsdirect.com/lis_png/PLDM/5R031172-00001.png if you have assured that the compressor is running and starting by removing the rear panel and you have also assured that the units main control board is functioning properly which is located at 500a on the diagram above. I would check this main board I personally have repaired many of these units and the LG electronics are not made well and usually become problematic within 2 years on this unit and a similar kenmore unit also made by LG. Have you assured that also the compressor fan is working as well? I await your reply
Thank you
Rick
Jul 01, 2012 | Refrigerators
Lg sxs fridge not getting cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | LG LSC26905TT Side by Side Refrigerator
Hi i have an LG GR-B206GVQA fridge freezer when we got up this morning it was not working at all i tried the fuse nothing wrong with that i tried the fuse on the control board on top of the unit that was...
Did you check the plug its self ? By plugging a lamp in the plug where the refrigerator is pluged into ? If the wall plug is good (could there have been bad weather) and then you plug fridg. back in and no positive results check to see if the inside light bulbs are good and work.
Aug 02, 2010 | LG LSC26905TT Side by Side Refrigerator
Lost power to the unit
I have the same fridge and found solution online. unplug it and plug it back in. worked for me and the service call was cheap.
Apr 07, 2010 | LG LSC26905TT Side by Side Refrigerator
Oct 26, 2009 | LG Refrigerators
Refrigerator is not cooling/freezing & control panel is flashing
I WOULD UNPLUG UNIT FROM OUTLET AND WAIT ABOUT 5 MIN. THEN PLUG BACK IN. IF WORKS YOU RESET THE BOARD IF DOESNT WORK THENYOU MAY NEED BOARD REPLACED. HOPE THIS WORKS
Sep 23, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Cold air not getting from Freezer to Fridge
I actually know nothing about refrigerators, but was able to fix the same exact problem where cold air was not getting to the fridge side of the side by side. The freezer was working just fine. I unplugged the fridge and freezer and tore all the shelving out to get behind a panel in the back of the inside of the freezer. There is a pass-through between the freezer and the refrigerator at the top back of the freezer on the side-by-side refrigerator. The passthrough was totally frozen over and blocking air from passing through and cooling the refrigerator side. I let it all de-thaw and then was able to pull the chunks of ice out, and all seems to be working great now. Be careful getting the ice chunks out as there are some controls there - it's probably best to just let it all thaw and melt by itself - which wouldn't require tearing all the shelving out. One could simply let the freezer dethaw for a day and then plug back in and both sides should work just fine.
Aug 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
66 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
