Question about Electronics - Others
Lanzar sd82 input output plug layout - Electronics - Others
Can a back-up camera be installed in a lanzar sdn695 bt if yes how to do thanks ted
sure can !! this head unit has three composite video input jacks on back of unit (three stereo sound jacks as well) if your only using say one of them for your dvd or vcr then that leaves you one to plug in a back up camera , it of course is sold separately , but any good composite output camera will do , and of course wire needs to be long enough to reach from rear bumper to lanzar head unit in dash , so be mindfull of that , after its all connected just select composite input you have it connected too , and violia !! there your view of what's behind you !! a rather neeto thing to do is connect two cameras to your spare inputs , one front and one back , if the front camera is infared enabled , it will help you see thru bad weather !!!!as infared isn't encumbered by using viable light that gets all scattered in fog and heavy weather , that's how helicopters land in bad weather !!
Oct 15, 2016 | Lanzar SDN695BT
Amp wont play
Quick test...with your Lanzar volume all the way down, connect MP3 player or other type audio source directly to the subwoofer input connection. Play audio and slowly increase volume control. If subwoofer is working using this method, reconnect and check for audio output to Lanzer connection problem, or subwoofer "settings" issues with the receiver.
Nov 11, 2013 | Lanzar VCTBS8 Vector 8-Inch Super-Slim...
Lanzar SDBT73N the preamp output dont wotk on my equalizer. But if i connect direct to the amp it work perfect...
equalizers have a tape loop type input/output, there is a button to push that sends either the processed , or unprocessed signal through, check your connections again, power everything back up, and look for that button.
Oct 17, 2013 | Audio Players & Recorders
I have a Lanzar HTG2600D amp, Iv hooked up systems for years so its not the obvious. The green light is on, everything it hooked up, the fan is running but there is no sound. I pulled the base cover off...
did you run direct to the speakers or to the rear of the radio to split factory wiring. Check to make sure that you are connected to the correct side of the wiring behind the radio. If that is correct, then check the input of the amp. Try a different source and see if you get signal. Make sure your wiring is not crimped.
I use my ipod and hook it to an 1/8" x RCA splitter and plug direct in the amp. try to isolate the amp as much as possible. 1 speaker to outputs and 1 source you know works. Then test from there.
Jan 06, 2011 | Lanzar HTG2600D Car Audio Amplifier
I am not sure how to use usb port on car audio
Read the manual and find out the maximum size jumpdrive you can use, and put your music on jumpdrives rather than burning up cd's. i use it in my car. its awesome if your mp3's are tagged with artist/title
Jan 03, 2010 | Lanzar SD82 Car DVD Player
Intaller Manual Lanzar SD32MU
output socket
hello, where can I get a output socket for my lanzar SD33MU, that is the socket that goes into the radio/dvd player, It is 18 pins.
With great regards Lody Alblas
Nov 30, 2009 | Lanzar SD32MU Car DVD Player
I need repair help. no schematics
Blown Mosfets
A thumbs up would be greatly appreciated if this answer is helpful to you. need-repair-help-no-schematics-zb4bomd1rt4qms0dqd12kkt2-5-0.jpg
Nov 08, 2008 | Lanzar VIBE266 Car Audio Amplifier
I have a lanzar mxa232 there is a L & R low. I do not have that on my head unit. How do I tie them in?
You would need a Line Output Converter (LOC) to convert the speaker level of the head unit to preamp level.
The amp also has speaker level inputs but the LOC will probably produce better results.
Let me know if you have any other questions.
Aug 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Sonance Volume Control VC50B
Hi how did you go, still happy to help.
regards
robotek
May 04, 2008 | Audio Players & Recorders
Please save my 50c
sounds like inputs are blown or channell blown!!! are you running high output preamp???
either way cheap fix,i had to repair a few of the opti inputs last summer for a customer if you need more info drop me a line 574-220-0162 Randall
Nov 18, 2007 | Lanzar OPTI 50c Car Audio Amplifier
Electronics - Others Logo
513 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
