Question about Nixon Lodown Tide watch
Display not showing
Won't go through the modes
Skmei 0817 black digital watch-user manual
WATCH KEYS: Top RIGHT=S1 Bottom RIGHT=S2 Bottom LEFT=S3 Top LEFT=S4
SKMEI WATCH User Manual Model 0817
Operating instructions:
In normal mode modelDisplay: Week-Minutes-SecondsPress S1 show Month and DatePress S2 button to show Alarm Hours and MinutesModes Covert: Press S3Modes of watch:
In normal display mode: Press S3> chronograph mode (stop watch)>time setting mode>>>(then back to beginning)
Chronograph function:
In normal display mode: Tap S3>enter chronograph mode>
tap S1 to start>
tap S2 to lap time>tap S2 read time>tap S1 to stop>tap S3 to exit tap S1 to stop
tap S2 to reset>tap S1 to start ...then begin againChime of every hour ON/OFF:
In normal mode hold S2 and then tap S3, if all icon of week on means Chime ON, otherwise means off.Alarm Setting:
In normal time Mode, tap S3 twice enter into Alarm setting mode, and the Hours flashing Tap S1 to adjust correct hour of your alarm. Pay attention to AM/PM (Military 24 hour display)Tap S2 the Minutes will flash. Tap S1 to adjust correct minute of your alarmTap S3 to save/exitTime & Date Setting:
In normal time Mode, tap S3 three times to enter Time & Date setting mode and Seconds flashing.Tap S2 and the Minutes will flash. Tap S1 to adjust minutes ("H" is 24 hour format)Tap S2 and the Hours will flash. Tap S1 to adjust the correct hoursTap S2 and the Date will flash. Tap S1 to adjust the correct monthTap S2 and the Weekdays will flash. Tap S1 to adjust the correct days (M=Monday, T=Tuesday...)Tap S3 to save/exit.Back-light setting:
Hold S4 will show all kinds of colors (blue, green, red, cyan, purple, yellow, orange) Just stop hold the button, last color lit will be memorized to set as current back light. 9b7a554e-43c1-4abb-a52d-3caf02dd616f.jpg
Jan 14, 2012 | Watches
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
  • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
  • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    HOW DO YOU SET A LADIES ARMITRON ALL-SPORT WATCH WR330 OR 45/6990?
    mcdevito75 here, One of the buttons should show MODE on the case of the watch, press that MODE button and see flashing, now press the set button to set time, each function you set, Time, day, date you have to pess the MODE button again to move onmto the mext function. Once all the functions are set press mode again and see a steady display.
    Jun 21, 2010 | Watches
    I have a Series 118 Pierre Cardin Quartz alarm with 3 buttons: Light, Set and Mode; I can't figure how to set/change the time
    mcdevito75 here, The mode button is the button you need to depress to set the mode of the watch. Depress the mode button once, see if anything on the face is blinking, if it is use the set button to adjust the time/date You may have to depress the mode button twice or depress and hold down the mode button a couple of seconds to get the face/display of your watch to blink, after you make 1 adjustment to move to the next depress the mode button again until you get to the next adjustment, or the next function to set on your watch. After you"ve set all the functions depress the mode button again to stop the blinking a show a steady display.
    Jun 12, 2010 | Watches
    Garmin Forerunner 50 Train Display Settings
    I was having the same problem and came across your post - I figured out how to change the secondary display.  While in Train mode, with your foot pod activated, hold the View button.  The secondary display will change and say "CAD" or "PACE"...keep doing this until you get to the right display.  Hope this helps!
    Jan 15, 2009 | Garmin Forerunner 50
    How do i set the time on 1440 T5K085
    The instructions that came with my watch didn't work but after playing around with the buttons for a while i final came up with this: Press the mode button for 2 secs. The first display is the alarm. Press mode again and the time shows with the seconds flashing. Use the set button to change seconds, minutes, hours. Use the start/stop button to change from seconds to minutes to hours.This will then take you to change the month, date and day of the week. Mode takes you back to the start (time display). The alarm is changed in the same way.
    To change from 12h clock to 24h clock keep the set button pressed (the alarm time is displayed) and press mode, the 'A' will disappear when in 24h mode
    When the time is displayed press the start/stop button to show the date.
    Not sure how to use the countdown timer or how to stop the alarm yet though!
    Aug 13, 2008 | Timex Watches
    Compass wont work correctly
    if your hands aren't straight when you use the compass try this to sync the hands.
    1. Press and hold the middle button to enter T-Touch mode.
    2. Press the centre area on the face twice to display 24hr/12hr
    3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
    4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
    5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
    Oct 10, 2007 | Tissot T-Touch T33759851
    Nixon Lodown Tide watch Logo
    Top Nixon Watches Experts
    Ansel Alberto
    Ansel Alberto
    rhodesworks
    Are you a Nixon Watch Expert? Answer questions, earn points and help others
