Question about ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Esa 42" plasma tv used as a pc monitor
I have a Compaq Presario Model # S6500NX. When I first connected the tv to my pc it was great but gradually the screen started having a lot of red dots, it would get garbled and flicker then eventually shut off. If I shut the tv off and then turn it back on it the resolution is okay but eventually it starts messing up again...I have tried updating all drivers but no luck...any suggestions???
3 Suggested Answers
  • 74 Answers
SOURCE: my fan is not working picture fades out when over esa plasma tv
need to bring to your tv service center before it blows out and becames more expensive to fix only a tv tech will be able to fix it,,
Posted on Dec 16, 2009
  • 148 Answers
SOURCE: I have a ESA 42
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not ) then please rate, thank you!312136d.jpg
Posted on Feb 04, 2010
I have a Compaq s6500nx. I have dsl connection through the ethernet port. After lighting struck nearby, I can no longer connect to internet. The modem is still operating correctly and I have changed...
I would suggest before you do anything you have the DSL provider come and check the line and equipment to verify it is working ok. Then if it is all ok, then you would probably need to replace your network card.
Sep 22, 2010 | Compaq Presario S6500NX (DQ181A#ABA) PC...
My 42 inch plazma turns on but ther is no picture
my ESA 42" plasma tv turns on no picture and no sound.
Jan 30, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Connect DVD to ESA PDP4294LVI plasma tv
coaxial cables are great for HD boxes and usefull components like that but as for D.V.D... dinosaur feed!
get a converter from "The Source" that will convert coaxial analog to yellow component Video and rca audio. and you will be laughing :)
Trust me i am the flat pannel guru! :)
Mar 14, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Need to find parts for my 42 inch plasma tv. #pdp4294lv1 model year:2004
The pdp4294lv1 is a re-branded Samsung monitor, here parts available online: PDP4294LV1.
To find all parts you need to look for part number on service manual, and then purchase same parts from different manufacturers. Alternatively call the seller to get parts.
Here the service manual.
SM-PDP4294LV1X
Mar 11, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Motherboard crashed in My HP Compaq Presario S6500NX
According to these specs it should be an Asus A7V8X-LA. This link will show you a list of these boards available on ebay.
Feb 23, 2009 | Compaq Presario S6500NX (DQ181A#ABA) PC...
Connecting my compaq presario 2200 to my panasonic viera 42"
If your computer has a VGA port on the side then it has video out. I've never seen a laptop without one but I guess that does not mean they don't exist :) I'm not sure what model of Viera you have, but the one that comes up on Amazon has a VGA input built in. If yours does then a simple old school monitor cable from a desktop computer will do the trick.
Here is a good one cheap:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10201&cs_id=1020101&p_id=3621&seq=1&format=2
If not, you can buy a VGA adapter:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040113&p_id=2509&seq=1&format=2
Also, if you want audio to play through the tv/stereo, you will need to get a cable to carry audio as well. This is what you will be needing:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=663&seq=1&format=2
and this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2009&seq=1&format=2
The stuff I linked to are for 25' so you can hide the cables around the room from wherever you would be sitting but you get the idea.
If it gives you hope, I did this with my Fathers compaq laptop to his panasonic 50" plasma and it worked great!
Jan 03, 2009 | HP Compaq Presario 2200 Notebook
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Trying to connect note book to Plasma Tv.
hhmmmm...does your compaq have a special video card or upgrade by chance?
Feb 16, 2008 | HP Compaq Presario V2000 Notebook
ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
Top ESA Televison & Video Experts
Colin Stickland
Colin Stickland
matt martin
matt martin
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
