Question about Sanyo EM-P540W Microwave Oven
Manual for microwave oven
Though my microwave sounds like it is working, food/liquid do not heat up
chie-chie
  • 98 Answers
SOURCE: Sanyo microwave mod # EM-2100GS
unscrew the unit replace fuse near the transformer. this fuse is for heating....
Posted on Feb 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: faulty microwave oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
SOURCE: My Sanyo microwave oven (model
You will need to replace the magnetron. Click on the link below to view the part needed to get your Sanyo microwave oven working again:
http://www.repairclinic.com/PartDetail/Magnetron/373303
http://www.repairclinic.com/Shop-For-Parts?s=t-EM-5665W-%3d%3d
If you are not experienced in electrical repair it may be cheaper (and safer) to just buy a brand new microwave vs. trying to repair your old one.
Posted on Dec 15, 2010
  • 8909 Answers
SOURCE: My microwave isn't heating my
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Jan 12, 2011
  • 8909 Answers
SOURCE: My Sanyo microwave oven (model:
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Hope that helps.
Posted on Feb 24, 2011
My Delonghi AM820AGX microwave no longer heats up liquids/food. It turns on and looks like it works, but when I test the liquids/food, they are still cold. I could have possibly changed the settings...
It souds like a busted MAGNETRON, and replacing it usually costs almost the price of a new oven...
Nothing to do with a setting... Sorry!
Apr 15, 2011 | Microwave Ovens
Argos own brand Cooksworks Microwave only one week old. Worked fine initially now is not heating food. Microwave is making all the right sounds as though the food is heating, but when door is opened the...
Hi,<br /> If this unit is only 1 week old, I would be calling the manufacturer tech service dept. Either they will send someone to fix it or they will have you return it for a replacement...<br /> Sounds like the Magnetron has failed....<br /> <br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Microwave Oven Basic Troubleshooting Tips<br /><a href="http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting" target="_blank">http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting</a><br /><br />heatman101</span><br />
Aug 26, 2010 | Microwave Ovens
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
The microwave has worked very good but latley
check the thermostat mounted on the side of the magnetron,it has 2 wires on it and opens the circuit to the magnetron if it overheats,they can get weak and open too soon so the mag can't operate long enough to properly heat the food,to test it just bypass it bo tying the 2 wires together,then if it cycles properly just replace the part,don't leave it bypassed though because it is for fire safety
Mar 28, 2010 | Panasonic NN-S542 Microwave Oven
My GE Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
heatman101
Mar 19, 2010 | GE JE2160 Microwave Oven
Doesn't heat food or liquid.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 25, 2009 | Kenmore 62622 Microwave Oven
Feb 02, 2008 | Sanyo EM-Z2100GS Microwave Oven
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
