Question about explorer moulding - bumper bar
Remove rear bumper Ford Explorer 2004
Removal and replacement
    Genius:
  • Ford Master
  • 2,494 Answers
Remove retainer bolt,s inside the trunk and under body .some bolts could be hidden under rubber plug covers.
Posted on Nov 17, 2015
2008 ford escape. removal of rear bumper cover
Pop the Hatchback open and remove the connectors
from the top of the bumper cover.
Optional Step: Using a Floor Jack, raise both sides
of the car in the back, supporting both sides with
jack stands, and remove the rear wheels.
Using Torx Bits, remove the inner rear wheel well
lining.
Get behind the rear wheel well and loosen the bolts
holding the bumper brackets on. They're pretty
difficult to find and remove. Be Patient. Do the
same to the other side.
Remove the rear bumper cover by pulling the cover
outward from the part nearest the wheel on both
sides. Once removed, take off the 2 black mounting
brackets from the bumper cover.
Good Luck
Feb 27, 2015 | 2008 Ford Escape
How to remove bumper
1. Remove rear combination light assembly. A. Remove two mounting screws. B. Disconnect electrical connector from rear side of light assembly.
2. Remove bumper assembly. A. Remove four fasteners and four retaining screws from top of bumper assembly. B. Remove mud flap from bumper assembly. C. Remove two screws from bottom of bumper assembly. D. Remove two screws from side of bumper assembly. E. Remove four bumper mounting bolts from under of vehicle.
3. Install rear bumper in reverse order of removal.
Dec 22, 2013 | 2004 Kia Sedona
I have a 2006 Ford Explorer and 2 of my park aid assist sensor are bad. They are in the rear bumper. How would i replace the sensors? Is it really necessary to remove the bumper?
You only need to remove the bumper cover. Remove both tail lamp assemblies. Under the tail lamps you will a 10mm and a 8mm bolt, remove these. Look into each rear wheel well rearward and you will find a T20 torx screw on both sides, remove these. On the top of the rear bumper, between the bumper and the bottom of the liftgate opening you will find 6 to 8 plastic rivets that can be removed by pulling the center pins out, remove these. At this point you should be able to lift upward and rearward and release the bumper cover. Once the cover is free you must disconnect the electrical connector to the sensor wiring harness. With the bumper cover on the ground or a bench, you will see 4 9/16" nuts that hold the styrofoam bumper cushion to the bumper cover, remove these. Now you should be at the point where the backup sensors are accessable. When you install the new sensors be sure your electrical connectors click when they connect. these connectors go on hard and if they don't click you will be doing this job again. Reassemble in reverse order.
Hope this helps
Apr 01, 2010 | 2006 Ford Explorer
How do you get the bulb out of the holder. Rear license plate
  1. Unfasten the lens retaining screws and remove the lens.
  2. Twist the socket/bulb assembly approximately 1 / 4 turn counterclockwise, then remove it from the lens.
  3. Withdraw the bulb from the socket.
  4. Installation is the reverse of removal.
  5. it also helps to open the trunk first to easier see what you are doing.
Nov 22, 2009 | 1995 Ford Explorer
Need step by step instructions on how to remove a rear bumper cover on a 2007 nissan altima
Rear Bumper: Service and Repair
REAR BUMPER
Removal and Installation
REMOVAL
1. Remove the LH and RH rear combination lamps.
2. Remove both the rear wheels and tires.
3. Remove the LH and RH splash shields.
4. Remove the rear bumper fascia clips and screws, then remove the rear bumper fascia.
5. Remove the rear energy absorbing foam.
6. Remove the rear bumper reinforcement.
7. Remove the rear bumper supports.
INSTALLATION
Installation is in the reverse order of removal.
Nov 12, 2009 | 2007 Nissan Altima 3.5 Sedan
Need to replace license plate lights on 95 ford explorer. can't reach underneath the bumper. does the plastic assembly just twist off?
  1. From underneath the rear of the vehicle, grasp the lamp socket and rotate it 1/4 turn.
  2. Pull the lamp socket from the lens.
  3. Pull the bulb from the socket
  4. Installation is the reverse of the removal procedure.
Exploded view of the rear license plate light assembly-step bumper shown, other styles are similar
Oct 20, 2009 | 1995 Ford Explorer
I need instructions on how to replace the drivers side fog lamp on a 2004 Ford Explorer.
u need to get under the truck and remove the lamp from the back of the front bumper.
Oct 02, 2009 | 2004 Ford Explorer
S Type Jaguar rear bumper removal
how do you remove a front bumper off of an jaguar s type?
Mar 09, 2009 | 2004 Jaguar S Type
explorer moulding - bumper bar Logo
47 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
