Question about Dent Fix Fix Dnt-595ii Shark 2 Spot Weld Remover
Need more power
Iwant to add more power to m 110votl .i want to a 110volt transformer 220volt.
    Top Expert:
  • Dent Master
  • 3,698 Answers
No advantage; no more power. P= I x E
Amperage times the voltage. If you increase the voltage the amperage will just go down .
Posted on Aug 03, 2014
Can I use a bamix from usa 110volt in Europe 240v ? can bamix classic accept both voltage or I need a transformer 240v to 110volt
This product is intended for use in the United States and Canada and is built to United States electrical standards.
  • Made in Switzerland.
  • Apr 03, 2017 | Audio Players & Recorders
    Can I change a 110volt drill to a 240volt drill
    Yes.; You'll need a transformer. The very best sort of transformer is a site-transformer which takes an input of 240VAC and delivers 110V, but at 55V either side of ground.
    Mar 14, 2015 | Drills
    Conection 220volt in A 110VOLT
    Hi
    You've made a great mistake indeed. Contact any service technician. With some sets, there will be a protection fuse [over voltage protection]. If your set have been included this protection device, your luck. If not, you might have to replace the power supply section to this device.
    Gopakumar Gopalan Google
    Feb 26, 2014 | Pioneer CDJ-800MK2 Turntable
    Audio video control centre. digatal delayed surronds,model no str-d350z was plugged into wrong voltage,part burned out,can you help
    You have not specified the make/model. But if you set is having the transformer as the case may be, and you have plugged into the 220volt with the 120 volt settting, then the transformer would have burned off. If so identify the secondary voltage of the DC cicuit and use a 220volt transformer to replace. If you are not able to identify multiple tappings then you must get the primary of the burned tranformer wound for 220volts. If at all this is aSMPS unit then you will need to replace the full unit as the ratings inthe power will be different.Since you have not specified details of voltage and ratings,I am not able to advice more. Hope you decide. Good day
    Jul 23, 2010 | Sony Electronics - Others
    Lights & oven don't work, burners do
    If this is a 220volt unit make sure to reset both breakers in your electrical box. If it is a 110volt unit you may try reseting the board by unplugging it for ten minutes then plug it back in. Hope this works. There aren't any available repairs to the control center which would mean a new one! Thank You, Dana
    Aug 22, 2009 | GE Kitchen Ranges
    Does a companion 5 bose speaker have a fuse?
    You will need to change entire power supply/distribution circuit since you have managed to fry it all with twice the voltage required by the system. Speakers should be OK only the circuitry needs to be rectified and too by a professional/expert technician ...........sodeep
    Mar 31, 2009 | Bose Companion 5 Multimedia Speaker System...
    I accidentally plugged my Wii on a 220volt outlet. But removed the plug immediately. Now I tried to turn it on with a 110volt outlet, but it is not turning on anymore. Which one is broken? the adapter or...
    The possibility is you fried both. I would start with the power cord first that woulde be the cheapest thing. If that does not correct the problem then I hate to tell you but your game system is toast. Please just kee in mind next time to check both your system and the outlet that you plug in to.
    Feb 26, 2009 | Nintendo Wii Console
    MAKITACHARGER 220v to 110v problem after using of right converter
    hi all,
    I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
    Have fun and good luck
    Jan 07, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
    Dent Fix Fix Dnt-595ii Shark 2 Spot Weld Remover Logo
    762 people viewed this question
    Top Dent Home Experts
    john h
    Tom Chichester
    Are you a Dent Home Expert? Answer questions, earn points and help others
