Question about Hardware & Accessories
Hager EH711 clock not function
My EH711 clock is not working. Have this problem for 2nd time. After I switch off the power supply for the timer for few months. Now when activate again , the timer clock is not working.
2 Suggested Answers
SOURCE: How do I set my
Resourceful do-it-yourselfer will find following information helpful for solving problem.
Max Load 1000Watts incandescent
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
Manual uses several languages including English
http://waterheatertimer.org/pdf/Hager-EH711-Timer.pdf
Hagar 700 series analog timer has mechanical dial that rotates as time passes.
Segments located on outer edge of dial are moved down-and-out, or up-and-inward to set on-off times.
As dial rotates, segments move lever that turns Load on-off.
With segment timers, all consecutive segments between on and off times have to be pushed in place.
Since EH700 series timer has NO NC terminals, segment position is determined by how timer was wired.
This is because segments-in and segments-out turn different terminals ON.
As a result, the best way to set this timer is to push 10 consecutive segments down-and-out.
Leave rest of segments up-and-inward.
Then manually rotate timer dial to watch when Load turns on-off.
Hagar analog timers also have a switch located in bottom right.
This is the manual override switch.
Set switch in position "I" and then rotate timer dial to watch when Load turns of-off.
Set switch in position "O" and then rotate timer dial again to watch when Load turns of-off.
Manually rotating dial and experimenting with segments and switch will tell resourceful do-it-yourselfer exactly how to set timer.
Once segments and switch are set, then rotate timer hands until current time shows on analog dial face.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
How do you set a hager eh010 timer
switch the timer off or disconnect
turn the thermostat setting to low
that way it will not work when the solar section is producing enough hot water and when the temperature in the hot water system falls below the thermostat setting it will switch on the power
usable hot water temperature is around 60 degrees c and anything over that will scald the skin within minutes
low thermostat setting is 55 -65 degrees c
Aug 06, 2016 | Solar Hardware & Accessories
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
I have been using EH 711 for three years without any problem. Lately, the timer does not switch off and there is no way I can switch off the light during the day.
1) Hagar EH 711 analog timer has 24 month warranty
2) Check if dial is rotating and keeping good time.
Check if electric source is 80% rated value.
3) If dial is rotating correctly, change override switch, and possibly reverse all segments so segments that were pushed down are now up, and segments that were up are pushed down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 24, 2012 | Hardware & Accessories
Operating instructions for a digital timer Hager EG 203E
i set up the hager eg203 time clock i have the times correct but i can not seem to over ride it, meaning to switch the load on and off manually by passing the times, can enybody help, a big thank you if you can my mail is
mcglynncathal@yahoo.ie
Apr 29, 2012 | Hardware & Accessories
How to set Hager timer EH 711 from 7pm to 11pm
Hagar EH711 is surface-mount analog timer with segments located around timer dial.
Timer has 2-position slide switch with I and O.
Timer has NO and NC wiring terminals, and I O switch reverses terminals.
Timer dial can be rotated by moving minute hand clockwise with finger
Open following link for instructions that illustrate how to set analog timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Open following link to see Hagar analog and digital timers with illustrations and manuals:
http://waterheatertimer.org/Hagar-timers-and-manuals.html#700-series
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
Sep 07, 2011 | Hardware & Accessories
How to reset the hager EH711? Currently it is set to turn off the light at 7:30am and turn on at 7:30pm. I want to turn on at 7:30pm and turn off at 7:00am. thank you in advance.
Open following link for Hagar timers:
Hagar EH711 has segments located around the analog dial.
The dial rotates as time passes and the segments move tiny lever that turns Loan on-off.
The segments are pushed down and outward or up and inward to set on-off times.
The timer can be wired a couple different ways, so setting the segments up or down depends on how it was wired.
If you look at dial on your timer and see how segments are set now, that will give you the correct information.
If segments are down between 7:30am and 7:30 pm, then move those segments up-and-inward.
To check the timer after moving your segments, you can manually rotate dial clockwise and watch the load turn on-off. To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
The slide switch has 3 positions. 0 = ON all the time; 1 = OFF all the time, and Auto = timer turns on-off depending how segments are set.
Upvote the help.
May 14, 2011 | Hardware & Accessories
The timer works but gets "stuck" when it comes to the ON time. it will continue this cycle if i force it to click past the ON time; but when it comes around the next day it sticks again.
You posted under malibu power pack.
When clock motor gets weak, it can no longer push timer dial past the trip point switch.
Right now the clock motor is overheating and will stop functioning.
This timer does not have replacement clock motor, but comes with 5-year limited warranty.
Buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
For complete troubleshoot, trippers, manuals and warranty information:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Apr 14, 2011 | Malibu ML900TW 900 watt Power Pack Timer...
How do I set my Hager timer EH711 to on at 7pm and off at 7am
Mar 17, 2011 | Hardware & Accessories
I need to know how to set the "Sentry" time that came with the house I've bought. Thanks. James
1) It sounds like you have the EJ351.
Intermatic EJ351 is sometimes sold as Sentry
2) Open following link for the manual:
https://www.gpspool.com/customer/geposp/additionalinfo/OWNER%20MANUALS/Intermatic/IO%20-INT-%20EJ351-EJ353%20Wall%20Switch%20Timer%20Installation.pdf
3) Add a comment if this is not your timer, and say more detail about the timer.
I have extensive files on timers and might be able to find same-similar product.
Mar 06, 2011 | Hardware & Accessories
I have a hager eh 110 time switch on my pool and I cant set it. Any clues?
Hagar EH 10 is 230V analog time switch.
EH010 is 1" wide.
1) See large image of EH010
http://www.bewdirect.co.uk/home/m/Shop/id/3985/page/1/
2) See large image that explains how to set EH-010
http://waterheatertimer.org/images/EH-010-image-1000.jpg
3) With analog timers, there is a movable dial that rotates with fingers.
Pins or segments are located around edge of dial.
Segments are moved one direction or the other to set on-off times.
After segments are set, the dial is rotated to match current time.
The dial rotates as time passes, and segments move a switch that opens and closes electric circuit.
4) EH-010 is different.
Usually analog dial is located on face of timer like a clock face.
However EH-010 is only 1" wide, so dial is perpendicular to front of timer and is rotated with thumb.
5) I suggest setting a few segments one direction or the other and then manually rotate dial full circle to watch when pool equipment turns on-off.
This will tell you if segments should be set right or left.
I have not seen this particular timer, but it appears as if times on printed on edge of timer dial.
6) Timer has 240V clock motor.
So Hot line wires from circuit breaker connect to terminals 1 and 2.
This powers clock motor so dial rotates as time passes.
240V Line and 240V Load wires are connected as shown in image below:
Feb 10, 2011 | Electrical Supplies
Hardware & Accessories Logo
545 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
