Question about GE JEM31SF Microwave Oven
Microwave is totally dead. Maybe the fuse? GE JEM31SF
My GE Spacemaker JEM31SF microwave went dead. no light, no control panel. I bet it is the fuse, but I don't know how to check it.
MicrowaveSvc
  • 9047 Answers
SOURCE: ge spacemaker microwave
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave oven - just stopped stopped working
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
SOURCE: GE Spacemaker microwave XL1400
If everything else is running but the food is not heating, the microwave generator is shot and needs to be replaced... Unfortunately, you need to be certified in handling the units so the average consumer cannot buy one (at least not as far as I could find when I had to replace mine) .
Will cost $150 to $200 so unless you have a pretty fancy microwave it will probably cost less to just replace the whole darn thing - So much for going green!
Posted on Dec 24, 2009
GE spacemaker XL microwave oven blowing fuse
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | GE Profile Spacemaker XL 1800 36 in....
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
GE Profile microwave counter top lights not working after replacing lamps?
There is a fuse in GE models, but if that were blown, the oven would be totally dead.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you prefer, you can buy a new control circuit board and install it. It's a pretty simple job.
here.
Oct 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the fuse located in a GE Spacemaker II microwave model number J EM824_ _ _ ? I can't read the rest of the model number.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1430 Spacemaker is dead. Completely.
See my microwave oven safety file here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. How to test a high-voltage capacitor.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. My door switch help file.
If the fuse is easy to twist with your fingertips while it's in the holder, it's too loose.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 29, 2017 | GE JVM1430 Microwave Oven
GE PROFILE SPACEMAKER P/NO 8114-334-730 MICROWAVE TOTALLY DEAD!
Sorry Seanna, but I have been getting a lot of problems with GE microwaves. You can call customer care at 800-432-2737, but out-of-warranty repairs are very expensive. Sounds like your problem may be door latch circuitry which requires service. If your unit is old, consider replacing it as prices are very reasonable.
Ray
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave XL 1800
remove top cover of oven , check fuse and control unit, high voltage section and diodes and capacitor and magnetron,
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JEM31SF Microwave Oven Logo
50 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
