Home | Dell | (E210882) Motherboard | The Screen not com...
Dell Motherboard
Problem for Dell (E210882) Motherboard
The Screen not coming up.
By Henrybabs on May 21, 2009
I have Dell Rev A02 motherboard. Was working before. Wanted to upgrade the RAM, I had to check the type first. After checking , I put back the memory stick and power up. The fan was working, the board led was on and the CD Drive could open and close, the screen was no longer coming up. There is only one jumper with three pins. I removed and interchangedry the jumper on the pin. The screen came up and boot to set up.after clicking F10, it asked me to shut down and then put the jumper back to its original place. Since then the screen has not been coming up. I testd the CPU and the memory stuck in another motherboard, they were working. Kindly help
Clarification Request
Posted by graemevm on May 21, 2009
The jumper you moved is to clear your CMOS memory which memorises the settings of your BIOS setup. You don't mention if you put the jumper back to its original position or not?
Please let me know and also tell me if you have tried an add on diasplay card?
Best wishes,
Graemevm
Solution #1
posted on May 21, 2009
Not Rated)
kamal1984
Rank: Wiz  Dell Expert
Rating: 82%, 603 votes
ok
first check that cmos jumper it must be in 1-2 position may be it is in 2-3 position so it cant give disaply
then let meknow
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (E210882) Motherboard?
Answer
Answer
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,... (More)
Answer
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear... (More)
Answer
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother... (More)
Answer
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard... (More)
Answer
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14106
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
