Question about SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow
Need power adapter for 250 gb external - SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow
2 Suggested Answers
SOURCE: I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Posted on Mar 27, 2012
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
The computer won't recognize the simple 250 with just the USB plugs
It doesn't require a power supply You may need to install a mass storage driver. What operating system are you using? Vista? XP? Win7? Win8? 32 bit? 64 bit? Was the drive used on a Mac? Are you on a PC right now with it?
Nov 27, 2013 | Hitachi SimpleDrive Mini 250GB USB 20...
My Seagate Free Agent GO is not working. My laptop does not detect my external hard drive and external hard drive does not power up. Before it used to work good.
Either the power outlet it is plugged into does not have power or the AC power adapter for the drive has failed. Try another outlet. If that doesn't work see if Radio Shack has a replacement AC adapter or contact Seagate to replace it.
I hope this helps.
Nov 30, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Doesn't power up
IF POWER ADAPTER IS YOUR SUPPLY IT MAY BE BAD. IF DIRECT TO 115V THEN DEFECTIVE.
Feb 26, 2010 | Western Digital 250GB MyBook External USB...
I moved and mixed up my adapters.
Hi there;
Nomaly there is a sticker on the bottom of the unit that gives the power rating and it will tell you how much power the device has input and out put all of the information will be there for you ok best regards mike
Feb 15, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow Logo
23 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
