Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
Our Whilpool Duet has become very noisy when spinning. There is metal shavings on the floor and it looks like the metal (inner?) drum is not quite centered. Any clues? Does this happen a lot? It is only 3 year old.
    Problem Solver:
  • 9 Answers
Its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
Posted on May 21, 2009
Manual for Whirlpool front load washer #GHW9150PW1
Many Whirlpool appliance manuals are available here: http://www.whirlpool.com/manuals/ . Use the search function to find your model. The direct link to the manual for the GHW9150PW1 is currently http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208182674.pdf . Sears Parts Direct also has the manual; the direct link is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0606369.pdf .
I hope this helps.
Oct 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Frequent out of balance problem
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Aug 18, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Six year old Whilpool Duet washer on pedestal and level front and back still vibrates excessively and makes loud noise when spinning water out of machine. Is sitting on concrete floor. Have owned since new...
check the inner struts on the bottom of the tub you need to remove the front panel some have a split lower section so you can access inside where the struts are also check that the struts are not worn out hope this helps
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When the washer spins it makes a banging noise and the plastic around the tub shaves off
Thank you! We took our Duet 9150 apart and found that ALL THREE support arms were cracked. Same problem with shredded front tub also. My washer is a little over 7 years old. I called Whirlpool at the above number (you can't get "warranty service" but the parts service lady transferred me to the warranty dept). They were most helpful, and are shipping me both the metal tub AND the plastic which the metal destroyed, free of charge. Apparently your experience has shown them they have a problem with this...or I got a more helpful service agent!
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Screw stuck in door seal drain hole Whirlpool Duet GHW9150PW1
Magnet my friend :)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
''whirlpool duet makes big noise on hi spin cycle and sandy grey staf is coming out from drain hose''
you more than likely have a broken tripod leg on the metal basket inside, when it goes into the spin cycle the basket become un balanced and is rubbing on the inside of the front outer tub which is the sandy grey stuff you are seeing.
if its less than 10 years old it should be in warranty and you can have a whirlpool repairman fix it, you would just be reponsible for the labor, which will cost around 300
if you decide to fix it yourself, first take off the bottm panel on the front of the washer, and clean out the drain pump. (i found the cause of my problem in there, and to get the rest of the plastic shavings out. 2screws came off one of the legs of the tripod of the metal basket on mine). next you will want to take it apart, so that you can see the back side of the metal basket, (i suggest taking the shocks off the front and back of the tub asselmbly before as soon as you can get to them, they can break pretty easy.) one of the legs you will find ir broken, corroded, or missing screws.
if you have to replace any parts, the front outer tub is about 100, metal basket is 200, and shocks are 15 a piece at appliancezone.com
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MILDEW
if you think it vibrates now wait till you stack it more pressure downward on the floor will cause more viberation
May 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
661 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
