Question about Onkyo TX-SR307 A/V Receiver
Kenwood kr-v8080 reset - Onkyo TX-SR307 A/V Receiver
I have a kenwood KR-V8080 and i had 4 subwoofers hooked up to it. then one day it jus shut off an smoked a little. now when i turn it on an try an hook up speakers it sparks an the speaker pops. i dont kno...
You blew the amp. If you were running 4 subwoofers off of a dual channel amp you most likely running them bridged off of two different outputs. You most likely blew the resistor and because it was pushing more power then it could handle. Also when you bridge speakers it brings down the impedance which allows for the more power to course through. Suggestion is to buy a new amp that can handle 4 subs or 2 different amps for both sets.
Sep 13, 2012 | Car Audio & Video
Did I fry my Kenwood receiver with excessive input?
It is very possible that you lost a channel and the uit is in protect.
Apr 10, 2012 | Kenwood Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Where can I download an owners manual for a Kenwood KR-V8080 tuner/amp. Thanks
You can download at:
http://www.kenwoodusa.com/z_Support/Home_Electronics_Owners_Manuals/
Select your product number from the list and the download link will appear below. Four thumbs, please.
Jan 05, 2010 | Kenwood KR-V8080 Receiver
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Nov 19, 2007 | Kenwood KR-X1000
Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Aug 18, 2006 | Kenwood KR-V8080 Receiver
Onkyo TX-SR307 A/V Receiver Logo
21 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
