Question about Dell Computers & Internet
Arrow keys not working - Dell Computers & Internet
Rotate screen back to horizotal
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
The screen is horizontal and the arrow doesnt work right
Most video cards that support the rotating of the screen have a shortcut, which can be pressed by accident. This does not happen as often as one would expect but the key sequence is Ctrl + Alt + [arrow key]. Where [arrow key] is either the up, down, left, or right arrow key. Each one does something a little different. The Ctrl + Alt + Up Arrow should get you back in the right direction
Dec 04, 2010 | HP Pavilion dv6000z Notebook
My screen is turned to vertical and i dont know how to fix it
It is due to your video card program managing your screen display. For a quick fix, try these out:
  1. Close all windows programs.
  2. Hold the CTRL key and press the UP arrow on the "Arrow Keys".
  3. Try also holding the CTRL key and press any of the arrow keys and you should see the display orientation changes.
  4. If the steps 1-3 don't work, try holding the ALT key and press the arrow keys (ALT key instead of CTRL key).
  5. If step 4 still doesn't work, try holding the CTRL key + ALT key + the arrow keys.
These should work since CTRL + arrow key or ALT + arrow key are shortcuts of the video card program that is why you can mess it up sometimes. Just give it a try.
Jun 04, 2010 | Acer AC 501 15" CRT Monitor
Left and right arrow keys not functioning
check the arrow keys it it's also not functioning in the BIOS:
- restart the system and press F2 five times during the splash screen of the big blue DELL logo to go to the BIOS (System Setup). Then test the arrow keys.
- if arrow keys are also not functioning within the BIOS the the keyboard assembly needs to be replaced.
- if arrow keys are working within the BIOS then reinstall the chipset drivers and keyboard driver found in the Drivers CD/DVD that came with the computer.
Dec 26, 2009 | Dell Inspiron 5150 Notebook
Trying to change the intercom caller ID onthe M7324
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Oct 23, 2009 | NorStar Meridian M7310 Phone
Arrow keys
If the keys are working on a notepad or else while typing it the issue is not with the arrow keys but with the key controls of the game that you are playing. Please change the setting of the keys while playing game or else try playing another game using the same arrow keys, i m sure it would work.
Jun 10, 2009 | Dell Studio 17 Laptop
My EEE PC 4G webcam is not working
Go into the BIOS Setup (press F2 when the screen lites up).
Right arrow key to Advanced
Down Arrow key to Onboard Devices Configuration
Enter
Arrow key down to Onboard Camera
Enter
Arrow key to Enable
Enter key
F10
Enter
Hopefully that takes care of it. :)
Oct 28, 2008 | ASUS Eee 4G Notebook
Arrow keys do not function in bios
Arrow keys move the cursor into fields + or - keys change the values of the fields.
Sep 23, 2008 | Dell Latitude D600 Notebook
Tv signal locked
A: The TV is in Showroom mode. The following steps will help you switch to Home mode. 1) Press Menu button from the remote,
2) Press Down arrow key until you see the word Picture, then press the Right arrow key,
3) Press Down arrow key until you see Mode, then press the Right arrow key,
4) Press Down arrow key until you see Power Up, then press the Right arrow key,
5) Press Down arrow key until you see Home, then press the Enter key,
6) Press Menu button four times to exit out from the OSD Menu.
Dec 10, 2007 | Olevia LT27HVX 27 in. LCD Television
27 INCH OLEVIA LCD FLATSCREEN
I had the same problem....
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
The CC button should work now.
Sep 07, 2007 | Olevia LT32HVE 32 in. LCD Television
Computers & Internet Logo
117 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
