Question about Exercise & Fitness
Resistance on precor 576i will not increase
When I start a workout I cannot increase the resistance. The display remains at 1 and the resistance does not change. Sometimes after 3 minutes I can increase the resitance but only slowly and unpredictably. If I get the resistance increased then I can reduce it with no problem. I hvae removed the control boards, cleaned them and put them back. I removed the motor shroud removed cleaned and replaced all the connectors. and it did not help.
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 93 Answers
This sounds like it's the membrane on the console faceplate. It'll have to be replaced.
Posted on Jun 27, 2017
2 Suggested Answers
SOURCE: the resistance on my Precor elliptical 5.17 will
There is a small motor under the shroud that operates the resistance motor. It is about the size of a roll of half dollars. Have someone use a meter and check that you are getting power to this. When you turn on the machine the motor should move the resistance forward then back. You can hear this everytime you turn it on.
Posted on Mar 11, 2010
Precor efx 576i resets everytime user changes direction
Does the lift work? If not, the battery is dead. Replace it.
Feb 17, 2014 | Precor Efx 576i Experience Elliptical...
Tip
Too Much Resistance on Stepmill
The first step in troubleshooting too much resistance or constant resistance begins with the lower board. You will want to first verify that the Field LED is lit on the lower board. As shown in the video, the Field LED is off initially, when the steps are engaged it lights up, after about 5 seconds the light should go off. If the Field LED stays lit during a workout or after a workout is completed, this is a sign that the console is faulty. There is constant power being supplied through the console keeping a full load and causing no change in resistance. If the Field LED remains lit, the console needs replaced.
Too Much Resistance Troubleshooting Video for Stairmaster Stepmill SM916
on Feb 11, 2015 | Stairmaster Stepmill 7000 Pt
576i resistance not increasing precor
If the display stays at 1, then the UP button may be at fault, in which case you would need a new keypad.
Jan 02, 2014 | Precor EFX 546i Elliptical Version 4
Resistance
This could be caused by either a bad lower electronic board or the brake/generator. I am attaching a link to the service manual for you for further reference. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Jun 27, 2013 | Precor EFX 546i Elliptical Version 4
How do I fix my crosstrainer, magnetic resistance has stopped working
This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
Feb 15, 2012 | Exercise & Fitness
My precor efx 546 keypad comes on, the enter button accepts all the info and programs are displayed. 1. The quickstart button does not work. 2. Both crossramp and resistance do not move either when...
1. Sounds like you need a new keypad if some buttons do not work. 2. If those buttons do not work either, it sounds like you need a new keypad, possibly the upper board. Make sure the keypad is plugged into the upper board and the connection is not corroded. 3. Older 546s used an electromagnet to produce resistance, newer 546s use a generator and resistor to produce resistance. I have never seen a 546 that used a motor that moves back and forth to produce resistance. Some residential crosstrainers use a motor like you describe.
Mar 10, 2011 | Precor EFX 546i Elliptical Version 4
The resistance on my Precor elliptical 5.17 will not increase. All other functions on the machine work. Any ideas?
open shroud and find the circuit board unplug and plug back in all connection this may sometime clean any oxidation off the connector. this is what I've in their 546's should work on the 5.17
Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
Change batteries in consol of elliptical, but still the resistance or tension does not change or increase
their maybe a loose connection between the upper display and function controls I would pull apart the upper display and check the connectors between the two boards
What are the benefits of a Rowing Machine?
One of the major benefits of the rowing machine is that it assists in strengthening the torso, the upper body where most of our main muscles are located. In addition to, legs is constantly work out although in the lifestyle of today, the area around the upper body is used more than the legs. The use of resistance to workout the area around the upper body significantly contributes to improving the core strength of the chest, shoulders and forearms. With improved strength, it gives rise to an upper body strength that is more stable and solid to carry out our day-to-day tasks easily. The legs are firmly workout as well although not as much as the upper body but you will be able to notice the difference when you work out consistently. One of the better benefits of a rowing machine is that of calories burning but few use it mainly for that purpose as other fitness equipments such as the Nordic Track, stationery bike and treadmills can do so effectively. In addition to, the rowing machine can help to improve lean muscle mass and given that lean muscle mass burn off more calories for a given size, the body will utilize more calories to nourish the muscle. As a result, rowing machine effectively increases metabolism so as to feed the lean muscle with the requisite calories. Very few people know that rowing machine help to reduce the stress level and anxiety through the frequent use of it. Exercising makes a person less depress and edgy and it is one of the most beneficial and least appreciated of all the rowing machine benefits. Keeping our mental faculties alert and well is as important if not more than physical aspect of our health. To derive all the benefits mentioned, we need to effectively make the most out of the rowing machine. The information that we gather here will be very relevant to utilize the most from the rowing machine. Fully understanding the machine itself and its functions can contribute to us getting a complete and beneficial workout. Rowing machine mimic the actual rowing experience of a boat for the sole function of aerobic and strength training workout as well as for those training for rowing. The machine has been in existence for more than a century but only in recent years that it gains in popularity. The market for rowing consists of a few types of resistance and they are the air resistance, piston resistance, water resistance and magnetic resistance. All are equally effective and none can claim to be better than the others. Each has their own admirer and the types of resistance you choose will hinge on the relevance of your exercise as well as the state of your fitness level. To derive the most out of the rowing machine, you need to know the different types of resistance levels and the air resistance will increase in resistance as you increase your pace. The piston resistance is the most popular as it is so small and compact that allows the machine to be foldable and move around as well as easy storage. Water resistance comes close to the actual rowing experience and the workout is as intense and the magnetic resistance makes use of electromagnets which make it very smooth and quiet in operation. With lesser noise, similar to air resistance, it provides a great workout without disturbing other. Besides understanding resistance levels to fully utilize the rowing machine, the other extras are as important. The computerized digital display that provide all the functions of the rowing machine such as calories burned, distance covered, time and speed to better gauge our training. All these may come at an additional price but all is worth it. Rowing machine remains one of the best fitness equipments out there and with regular workout, the results are there to see.
Dec 01, 2008 | Kettler Rowing Machine Kadett Rowing...
Exercise & Fitness Logo
1,130 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
