I have a dell monitor connected to my hp laptop but its only showing up0 in the color red how can I fix this
What do I need to do to fix this problem im tired of looking at a pic that is red
  • 21 Answers
First thing first, have you try anoter video monitor and another video cable?
if they all get out red, you video port is shot. if they come good the maybe the VGA cable have some pin broken (bended) does happen a lot. then if the cable is good then at last monitor can be bad. look at the back if the connector is not broken.
now, if the monitor is reddish, and other are good on your source.
there is many electronic faillure that can get to this. neon inverter is one of them and neon itself also.
Posted on Jan 04, 2014
4 Suggested Answers
JMuskovitz
  • 135 Answers
SOURCE: about colors
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
Posted on Feb 21, 2007
sys_admin
  • 829 Answers
SOURCE: possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Posted on Jan 01, 2009
  • 55 Answers
SOURCE: red line on monitor of dell laptop
You may want to try another video cable. If that not it then you may want to open the OSD (On Screen Display) menu and see if it goes over that. If it dose you may have to get service from Viewsonic. If not then you may want to try the monitor on another computer to make sure its not traveling with the monitor.
Posted on Apr 22, 2009
HP S230 monitor won't connect to my Dell Inspirion 15 laptop via DP to HDMI cable
Hi Msdco1, 1st try fixing your laptop..... The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS..
ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
May 10, 2016 | Dell Inspirion 15
I have dell 1545 inspiron laptop. One day suddenly, the laptop's lcd screen shows colored vertical lines. I connected laptop to lcd tv and I could see desktop. I tried to enquire at various shops and
your LCD it toast its better to get it fixed. the cable only by-pass your lap top LCD thus allowint you to use your pc via another monitor sourse
Sep 27, 2014 | Dell Inspiron 15 1545 Notebook
Dell inspiron screen is turns red while starting and shows red instead of black color
Try using a different monitor and check if you have the same issue with the other monitor. If the other monitor works great, then you would need to replace the LCD of your computer.
Mar 13, 2013 | Computers & Internet
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
My monitor is not showing red colors? how do i fix
There is a number of possible reasons why your monitor lost the red color. A good guess, however, is a broken cable or connector. Check the plug and socket of the cable for bend or broken pins. If everything looks OK, try to change for a different cable.
If the problem persists, a pin of the connector soldered to the PCB internally may be broken. This is an easy repair for a service technician but I really recommend you do not do it yourself.
Feb 05, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
My monitor is not showing the proper colors. Green is showing up as yellow and red is as dark as black. When I unplug my monitor and the check cable message pops up, the red, green, and blue show up...
Do not put your speaker near your monitor and any device that have magnet on it. It will damage your monitor colors. If degaussing it not helps you, you can try to use your speaker. Move again your speaker near your monitor and use its magnet to remove the color scattered on your screen. Check also your cable connections. IT might some pins was skewed up. Don't open your monitor own your own. It's hazardous. It still holds thousands of voltage even not connected to the outlet. Bring it to professional if do you think you can't solve it own your own.
Jan 27, 2010 | Dell E771MM 17" CRT Monitor
Dell monitor 152fpc orange coloring replacing red
If you connect the monitor to a laptop's "video-out", do you get correct colours, or do you still get the "orange" ??
If so, then the monitor is the problem.
Apr 17, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
David Payne
David Payne
