Question about Sewing Machines
Button hole instructions - Sewing Machines
How do I use the button hole maker
Your owner's manual should have instructions on how to use the button hole accessory. The directions are vary from one machine to another so it is difficult to provide more complete advice.
You can also try searching the internet for web sites and videos for using a button hole accessory.
Apr 26, 2016 | Singer Sewing Machines
How to use a buttonhole attachment
You mark the fabric where the holes are to go, insert the button in the foot, snap on the foot, set your stitch dial to button hole, lower the button hole lever and GENTLY push it back. Put your fabric in the machine aligning the marks you made. Hold the thread ends and start the machine.
The instructions you are looking for are on PDF page 22 here.
http://www.singerco.com/uploads/download/1181_2273.pdf
Aug 23, 2012 | Singer 2273 Mechanical Sewing Machine
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
How do you sew button holes?
I am assuming that you have marked where you want the button hole to be. Here is the link to the manual for the 5050.
446_5040_5050[1].pdf The instructions for making a buttonhole are on page 36
Mar 28, 2009 | Singer 5050 Mechanical Sewing Machine
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Jan 06, 2007 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
234 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
