Question about Behringer Audio Players & Recorders
Behringer pmx2000 manual
Behringer europower pmx2000 preamp outputs have 3 outputs: (1)mon out (2)mon(left) (3)mon(R) IF I use MAIN OUTS (stereo) for FOH including gr.EQs which mon out terminal to take the signal out to feed independent fold back mixer AMP?
5 Suggested Answers
  • 43 Answers
SOURCE: behringer europower pmx2000 manual
I found it here.
http://www.bbmusic.bc.ca/behringer/PMX2000_medium.pdf
Posted on Apr 07, 2008
  • 4234 Answers
SOURCE: How to connect PA mixer with built-in amp to feedbk dstryr unit?
The feedback unit should be connected between the pre-amp section and the power amp section. As you descrubed the ST-out and P.Amp IN are the ones to use.
Dan
Posted on Jan 22, 2009
damneddle
  • 1607 Answers
SOURCE: I am trying to find the weight of my Behringer
Weight (net) approx. 15 kg (33 lbs)
You can rate my answer if this helped you.
Posted on Oct 04, 2011
  • 5603 Answers
SOURCE: Europower PMP5000, In the Front Panel there is a
Yes, you can use both the main1 and main2. They are independently driven and please note that they are PSUEDO balanced drives... that is the cold side of the balanced line is NOT driven as a complement, but is merely returned to signal ground by a 120 ohm resistor. This CAN cause hum problems or noise pickup depending on the connected equipment and ground loops. Best to run this into amps/speakers thaat have TRUE balanced inputs and also keep the power source the same for all devices.
Posted on Nov 02, 2011
Europower PMP5000, In the Front Panel there is a Main 1 & Main 2 output, can I connect both to 2 Amplifiers so I have four independent outputs or 2 Stereo outputs? Can I Use these two outputs + mon 1...
Nov 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I am trying to find the weight of my Behringer Europower Model PMX2000 weight
Oct 04, 2011 | Behringer EUROPOWER EP2500 Amplifier
The weight of my Europower PMX2000 Beheringer mixing amp. I have a weight limit for flight issues.
For that power the amp is fairly light. The USUAL solution is that musicians RENT equipment near their venues to avoid shipping expense. Your equipment is also very vulnerable to damage during flight.
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
What is the rms power output of ep 2500?
This unit has the following output specs:
2 x 1200W into 2 Ohms (stereo)
2400W into 4 ohms bridge mode (mono)
Dan
Aug 17, 2010 | Behringer EUROPOWER EP2500 Amplifier
My behringer europower EP2500 poweramp has a bad hiss on channel 2 What could this be?
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Jul 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
Left stereo output dead
Try switching the speakers and seeing if you have power on the left side, if not then you may have a bad input from the receiver/cd player or bad amp output
Jan 22, 2010 | Behringer EUROPOWER EP2500 Amplifier
I need a circuit diagram for a Behringer PMX 2000 to repair a left hand power output problem
Here you go..
I posted your schematic on my temporary web files site; so,
download and save within the next two weeks cause it might go away..
http://ca.geocities.com/artiedc/PMX2000.pdf
Ed
Jun 21, 2009 | Audio Players & Recorders
How can i do this
Hi
the crossover has 6 output and 2 inputs in stereo type! you need amplifier to this...
Thanks!
May 16, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer europower pmx2000 manual
I found it here.
Sep 14, 2007 | Audio Players & Recorders
66 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
